996 Forum 1999-2005
The Dyno Thread
Old 06-12-2016, 08:29 PM
Ericson38
Ericson38's Avatar
Originally Posted by Triple Black
Here is the readout from the original engine in my MY04 996. About 30K miles on stock engine, cats removed and custom ECU tune.
291 peak RWHP @ 6400 rpm
261 peak torque @ 4600 rpm
You have the classic 3200 RPM torque dip, but some plots don't. I wonder what that is all about ?
Old 06-13-2016, 08:37 AM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
The torque dip at 3200 is often removed with "smoothing" settings in the software. The 5,252 RPM dip is the same. This basically comes from the actuation of the variable valve lift, and then again by the variable valve timing.
If you guys really want comparisons, get the raw data broken down every 250 RPM across the board, then average the TQ and HP. This is the main thing that I look at when grading my engines. I pay zero attention to the peak numbers, other than to average the data from 500 RPM before, and 500 RPM peak. I am concerned about increasing power across the entire rev range, not just at peak.
Lots of people think that just because they have a higher peak power value that the engine is more powerful. Thats not the case, especially with stock displacement engines, which generally lose power down low, as a compromise to make more power up top.
Old 06-14-2016, 10:40 AM
Tdream1
Tdream1's Avatar
Here is my graph with no correction. Mine is an '03 C4, BMC drop in filter, snorkel delete and a Softronic OTS tune.
Old 06-14-2016, 11:13 AM
Hardback
Hardback's Avatar
3.8 rebuild after break in miles, front drive decoupled for dyno runs. I've driven 30,000 miles since then. Maybe one day I'll do a custom tune. Fabspeed 200 cell cats and bmc air filter only.
File Type: pdf
Old 06-14-2016, 11:41 AM
Tdream1
Tdream1's Avatar
Hi Jake,
Please import this raw data into Excel and see what you think.
Cheers,
Scotty
File Type: txt
Old 06-14-2016, 02:08 PM
Slakker
Slakker's Avatar
What's the best way to get RPM on a Dynonet? I would like to use the same shop again since they did my HP baseline but they are clueless when it comes to p-cars.
Old 06-14-2016, 03:19 PM
Flat6 Innovations
Former Vendor
Inductive pick up on one of the coil pack leads. We also sometimes use an optical pick up with a target on the crank pulley.
Old 06-14-2016, 05:00 PM
joe-1972
joe-1972's Avatar
2001, 3.4, generic headers, long crossover pipes no cats, B&B cans, CAI, Pulley... motor rebuilt by MBMotorsports... 5-8000 miles ago...
Old 06-14-2016, 05:26 PM
alpine003
alpine003's Avatar
Joe, that seems pretty strong, especially on Mustang and for a 3.4L. Was this done in the winter by chance? Great numbers for a 3.4.
Willing to bet you can extract another 5-8hp with a tuned ecu.
joe-1972 (07-29-2021)
Old 06-14-2016, 06:03 PM
TonyTwoBags
TonyTwoBags's Avatar
Nice looking car Joe, the side graphics fit it well with the aero. Strrrrong dyno as well
Old 06-14-2016, 09:19 PM
501Max
501Max's Avatar
Old 06-14-2016, 11:14 PM
Slakker
Slakker's Avatar
Originally Posted by 501Max
Here is my Raby product in a 2002 996... I've had the opportunity to take it on track a few times since its' return a couple months ago. The power is on tap, predictable, and a lot of fun to rip around the curves.
Now that's a good looking dyno. Great low end torque and look at the power band from 5-7k. Very nice.
Old 06-14-2016, 11:16 PM
Sneaky Pete
Sneaky Pete's Avatar
Here is mine. This all taken at the wheels. This will change soon because my car is back at Jake's having some enhancements done. There is no longer a slippery slope...its called a cliff!
Couple comments:
Joe looks like yours has been corrected at the flywheel. I'm thinking you might be 18 to 20% less at the wheels compared to the other plots posted. Tdream1 I'm thinking its the same for you too. Not calling you guys out but just thinking what is feasible with a 3.4.
Old 06-15-2016, 07:51 AM
Tdream1
Tdream1's Avatar
Sneaky Pete, mine is a 3.6 and is @ the wheels on the Mustang dyno with no correction applied.
Old 06-15-2016, 10:23 AM
Flat6 Innovations
Former Vendor
Yes it is corrected to Engine Power as Pete explains. It says so right on the plots. The Mustang software has a curve that can be applied to add the drive train losses that are expected, back into the plots. It says "Eng" at the top of those plots, because that curve has been applied. If it was wheel power, it would say "whp" on those plots.
This is a setting that the Dyno operator can choose which gives the engine the flywheel power rating projection, even though the power is gathered at the wheels.
I have spent thousands of hours of my life using dynamometers. I have 3 under my roof.
Quick Reply: The Dyno Thread
