2003 996 3.6 pictures ground location on cyl heads
getting down to the last few steps before engine installation after complete rebuild.
I have 2 wire harness grounds, left front cyl head , and right rear cyl head.
No t sure the correct location/orientation of these ground terminal ends.
Anyone have a picture of an engine out with harness still installed?
Glenn
Glenn
There should be only one ground strap connected to the bank 2 head where the cam timing tool screws onto.
Glenn
Glenn
Excellent picture I see then it goes under an electrical connector bracket by the air oil separator comma diagonally on the other side of the engine there's another connector but I think it's closer to the intake manifold close to the head I didn't see it on the second picture it's a similar ground termination do you have a better picture?
