New car and first Porsche on the way
#33
#35
#37
Well it finally arrived at my folks house on Friday night at midnight. Pics taken with a potato cam...
Spent Saturday effing around getting the out of province inspection done and getting it registered in BC. Then a nice drive up the Sea to Sky highway home with my son. Windows down so we could listen to the sounds from the PSE, awesome!
Got a few things that need to be sorted out on it (squeak in the steering wheel, think it's rubbing on the horn ring, wheel off and a little vaseline on it should do the trick), clunk in the rear going over speed bumps (swaybar loose? End links/bushings? will go in an check it out) and it's probably due for motor mounts (the exhaust tips are a little lower than they should be but nowhere near where I've seen some sagging. All pretty basic stuff I'm happy to pick away at over the next couple of weeks.
#38
*if the steering wheel squeaks when it is turned far left or far to the right, it is most likely related to the replacement of the turn signal and 3 other "stalks" which come as one part - there is some sort of bushing that needs to be present and sometimes it is not replaced.
look thru your service records and see if the 4 stalk part was replaced.
#39
It happens when the wheel is turned even a small amount in either direction. It sounds like it's coming from right behind the wheel itself. I did a search here on RL and from descriptions from other threads it sounds like it's the wheel rubbing horn ring.
#41
Glad you're getting the motor mounts done. I mentioned this to Pfaff when I was looking at the car as I could see the passengers side exhaust about 1/2" lower than drivers. They told me it looked normal and didn't think there was anything wrong. Regardless, it looks like you've got yourself an amazing car and I hope you enjoy it!
#42
Congratulations on a Beautiful car. Too bad you got the second fastest color just under Arena Red
I keed of course. Again Beautiful car and congrats on finding it.
Marc
Marc
#43
#44
Yeah, funny hey. I think there was enough interest they figured they wouldn't have to bother. Have a set of wevo's coming.
