Replacing the oil pressure sender
Just ordered it (thanks Jason@paragon!)
Any tips for replacing? Looks like I need a right angle box wrench attachment for my ratchet.... 19mm?
Before wrenching with the 19MM crow foot wrench remove the rectangular aluminum heat shield (2x10mm bolts) from the right side of the engine for more clearance.
Thanks guys! The current one is temperamental.... Some occasional bouncing and every once in a while it shuts off.
Drove all day yesterday and it was perfect.... So I think it's on the way out.
I'll grab a crows foot and grind it down!
Before you change it out completely, clean off the terminals to the existing one, sometimes it's just a bad contact. Did that with mine, cleared up all the problems.....been a couple years now!
