Clutch was going out, and now is out after a harder than usual drive home (I guess the discussion I was having about politics worked me up a little), and/or it sounds like a brake is dragging or grinding when going slow, so not sure what that's about or if it's clutch related.
While I can't speak to your clutch problem, for the brake sound, check the backing plate that attaches to the wheel carrier. It's not uncommon to get a small rock/pebble stuck between the plate and the rotor. Also, it's not uncommon for the plate to get bent and rub against the rotor (it's very light sheet metal). Good luck
