Trade the 99' towards a Turbo?
#32
The fitting are completely different then glued in pipes though, its a separate issue. While glued in these plastic fittings actaully crack and then leak. Same issue seen in the 955 Cayennes with its coolant pipe failures.
Sharwerks has the fittings for sale
This set of stainless steel coolant pipes replaces the weak factory plastic units that are prone to failures.
This item is considered preventative maintenance and should be installed on all 997 Turbo (2007-2009), 997 GT2 (2008) and 997 GT2RS models. This part is not required or compatible with 996 Turbo models (which already have a metal tube).
A known weakness of the GT1 engine is that the coolant pipes (6-8 per engine) come unstuck from various housings and cause complete catastrophic coolant failures.
Shark Werks Coolant Pipes shown next to the stock plastic parts:
#33
coolant pipes are glued in, sometimes these dry up or fail depends though. I have a 15 year old Turbo that's been tracked in summer hard every year and never had a issue. I think some engines may vibrate or move around to much and put stress on it who knows.
#34
#36
#37
If you want a heavier and even more dull steering feeling electronic awd car with a engine that is fitted with cost savings measures like plastic coolant fittings that crack with age, and pressed on cam sleeves that slip and the variable turbos don't hold up as well as the old ones that do not move. Then go ahead, get a 997.1 tt
plastic coolant fittings. How many have failed? yes, I want a real number, not a "well duh, i read somewhere that its been a lot."
Proof that the VGT turbos don't hold up as well? Evidence? Facts?
Pressed on cam sleeves...yup, that sucks.
talking about sucking, lets talk about your cracking tailights, your 2nd gear popouts, your ancient pcm, 4 piston front calipers, etc etc.
Lest we forget about the 70bhp power increase, as well as torque bump, reduced turbo lag, etc etc.
#38
yawn.
#41
#42
I am in Toronto and he is in NJ, Mid Ohio is somewhere in between us, though we can to other tracks, I know NNJR comes up to CTMP but NJMP is not a HP track at so he would lose that advantage. A 997tt even driven by an amateur should leave my slightly modified 996tt in the dust as its so superior.
#43
Have to chime in....
Had the opportunity to buy a 996 turbo with many modifications and ended up with a 3.6L N/A due to how much more I can actually use the power on local roads and tight twisters. I can push my N/A about 90% everywhere I go as where I couldn't do that with the turbo. I honestly felt as though I would never use the turbo to its potential and even the seller of the turbo car agreed with me.
#44
