How to remove stripped screw
What's the easiest (ie. quick and dirty) way to extract a stripped screw? I couldn't care less about the carnage; I just need it out. I have basic tools, including a drill, but no dremel. The offending screw is #9 in the diagram below (door panel). Thanks.
You could try an extractor bit, pre drill existing screw with cobalt bit then use extractor with 1/4" or 3/8" ratchet drive. Big box home project stores have them as well as most any auto parts locals.
From the looks of what it is I would just drill the head off the screw, remove the panel, and then you should be able to get a hold of it with pliers and turn it out. If it is really stripped you probably would want to center punch the head before drilling.
Marc
Marc
Received 1,198 Likes
Grab onto it with some small vise grips and give it a big yank. I'll bet you'll be able to pull it out along with the plastic grommet still attached. Sure would beat drilling and all that.
dremel...
If you can get at it without making a mess a little cutting wheel on a Dremel, cut a slot in what's left and use a flat blade screwdriver... the Dremel is worthwhile having around your shop anyway
With stripped screw heads, I've always had luck taking a torx screwdriver head (slightly larger than the screw size) and hammering it into said offending screw. It should be in there pretty snug. Attach the screwdriver handle, turn and the screw comes right out.
Day 2 update:
I couldn't get vice grips or hammer claw on it, due to the oddments door getting in the way.
So tomorrow I'm going at it with the drill.
I like that hammer idea, but this head is round and flat, nothing to grab on to.
Great ideas by all, very valuable.
Problem solved, thanks all. Turns out it's all plastic, very similar to the plastic rivets in the wheel liners, but phillips head rather than push pin. Came right out with large enough drill bit.
This happened to me too (same screw) last week. I knew it was plastic and just used a chisel to pop it off... then when I got the door panel off I removed the whole thing. Mine would spin but wouldn't come out.
If anyone else has this issue where the phillips part is stripped, you can heat up a screwdriver really hot and then just press it into the screw... the heat will melt a new pattern in there and then you can turn it out.
