Brake upgrade for 996.1 C2
Brake upgrade to 2007 GT3 PCCB specifications:
Calipers Front 380mm: 997.351.431.92 (L) 997.351.432.92 (R)
Calipers Rear 350mm: 997.352.425.98 (L) 997.352.426.98 (R)
Disc Front 380mm: Brembo steel rotors.
Disc Rear 350mm: Brembo steel rotors.
Aluminum Brembo hats for GT3.
Adapter needed for steering spindle on front brakes: 130mm spindle to 225mm caliper mounting holes.
Porsche adapter 997.351.505.04 is for a 142mm spindle to 225mm caliper mounting holes. This adapter is for a 997 C4 or Turbo upgrade to the larger 225mm six-piston calipers.
No adapters needed for the rear brakes.
Has anyone completed this PCCB upgrade on a 996.1 C2?
Will the above adapter work? Adapter specifications are not available in PET.
What are the disc or rotor hats required for the PCCB front caliper off set?
Is a larger master cylinder required for the six piston front and larger four piston rear calipers?
Thank you for your expert 996 advice.
Last edited by Blackpony; 03-10-2016 at 12:10 PM. Reason: Measured adapter 997.351.505.04.
Just to knit pick, the c2 suspension is slightly different than the c4 as is the carrier/spindle.
Former Vendor
We have a CCM brake package using Corvette ZR1 discs with RB 6/4 pot calipers for those cars equipped with 130mm mounting spread in both front & rear spindles.
Rotors will have the same build as those just released for 991 GT3, but the adapters will be made specific for different spindles and offset.
https://rennlist.com/forums/991-gt3-...r-991-gt3.html
Due to the variety of retrofitting combination from end-user in caliper, rotor and spindle/upright etc, we have decided to sell only the whole package to assure the fitment and system integrity, and will not sell just the adapter (bracket) in order to avoid compatibility issue and trouble.
Racing Brake just posted additional information.
https://rennlist.com/forums/996-foru...for-996-a.html
RB-CCB System for Porsche 996 (P/N 2C22 & 2C23)
Our Price: $16,646.00
Sale Price: $14,982.00
You save $1,664.00!
RCCB-POR-03
Brembo® System for Porsche 996:
GT-R Series; 6 Piston Billet Machined Nickel Plated Caliper, Curved Vane Type III 2-Piece Rotor Brake Kit, Front: 380x32mm $8,635.20 (Steel)
GT-R Series; 4 Piston Billet Machined Nickel Plated Caliper, Curved Vane Type III 2-Piece Rotor Brake Kit, Rear: 380x28mm $7,483.20 (Steel)
Sale Price: $16,118.40
GT Series; 6 Piston Black Caliper, Curved Vane Type III 2-Piece Rotor Brake Kit, Front: 380x32mm $4,411.20 (Steel)
GT Series; 4 Piston Black Caliper, Curved Vane Type III 2-Piece Rotor Brake Kit, Rear: 380x28mm $3,643.20 (Steel)
Sale Price: $8,054.40
Looking for Brembo CC Rotors.
You save $1,664.00!
RCCB-POR-03
