Window regulator repair sleeve
Has anyone used the EPS window regulator sleeve? My driver side window regulator cable has stretched a little so my window don't hardly go down anymore when the door handle is pulled. I was considering a new regulator then I came across this
http://europeanpartssolution.com/pro...repair-sleeve/
I'm wondering if this will do the trick. I did a search and didn't come up with anything. Has anyone ever tried this as an alternative to buying a completely new regular just for a slightly stretched cable?
EuropeanPartsSolution - window regulator repair sleeve
Subscribed
My question is not about cost. It's about design. The slight cable stretch is a very common issue. This looks like a much better design than the plastic oem part and may allows more adjustment range. I just wondered if anyone had real experience using it. If it works I'd rather fix the issue rather than replacing the entire regulator.
Great idea. This is the second time I've had this problem on the same (driver side) door and now that I'm looking closely, it seems the passenger side has stretch a bit also. If theres a better solution than replacing then (again), I'm all ears... Thanks.
It's help like yours that makes this forum so great... I hope I get a chance to pay it forward
