Oem suspension or TRW/ others just a good ?EPS
Am in the throws of rebuilding front suspension 99/996 - 106K on chassis
Many options on parts - anyone have info on what works on their build - control arm/ control link
Drop link
Also I have H&R coil over gas shock can they be rebuilt?
Sent from my iPad using Rennlist
Drop link
H&r coilovers use bilstein shocks for the street performance set and koni for the rss coilovers .
They are both rebuildable , if you've got a local track suspension shop they should be able to help , or contact h&r in Washington state .
http://www.hrsprings.com/about/
I used a full set of powerflex poly bushes in my suspension , a great upgrade .
Performance Shock Inc. @ Sonoma Raceway in Sonoma, CA can rebuild the shocks if I recall correctly.
Bringing this back up to hopefully get some more input. Does anyone have experience with the non-OEM control arms? I'm considering the ECS parts as an alternative.
The Merle German control arm bolted up perfect- think they are 120.00 each
Porsche twice as much and also German- I am sure you will get same specs
At 1/2 the price
At 1/2 the price
I just replaced my front control arms and "coffin arms" with the EPS replacements (Poly bushings, and replaceable ball joints). Feels great, and the price was right - $579.00 all in.
