Bough a dirt cheap 996 w IMS issue, but still running. What to look for?
#46
Agreed and given the damaged IMS, you need to split the case to replace it anyway.
The other side of the IMS is a plain bearing riding on the main gear pump.
Do you know what kind is the broken bearing? Looks like steel ***** in the photos. It lasted only 25k miles? The reason for the previous rebuild was also the IMSB?
#47
That's possible but unlikely...
unless that bearing had been replaced previously before the rebuild. Can you tell if the ***** are steel?
#48
#49
#50
#51
$7500 and that parts list is more of a refresh rather than a rebuild. If that was done because something (like the IMSB) had failed it would also suggest that the motor was not completely cleaned out. If that was the case then another failure was just a matter of time.
Either Ahsai or AWDGuy have a good pic in their build thread that shows how well the debris can get hidden up in places that flushing won't get out. Eventually it becomes unstuck and has its way with your "rebuilt" motor.
#52
#53
Do we know why it was "rebuilt" previously? (I thought you said in a previous post, but I don't see it in a quick scan)
#54
#56
I did the $7500 UFO rebuild and could not have been happier. I did it for a failed stock dual row IMS. Their $7500 rebuild comes with some no name after market bearing. They said at the time they never had a failure. Guess this is number 1. I had them put in the LN bearing for an extra charge. At the time I was not sure if it was a good decision. Guess it was a good call.
Not sure of the timing of the split, but the two guys who ran it separated and one started 9xx motorsports so you may want to call them.
#57
There's a decent set of clips a guy did rebuilding his boxster on YouTube if you search 986fix, engine is the same as 996, it will give you some insight into what you are facing, I've just rebuilt my 996, there's a lot to learn and as others have said its not cheap, you will spend two grand just on consumable parts like new shells , stretch bolts , gasket set , rings !! Rings are expensive!! Valve guides , new ims don't forget, then tools , don't want to put you off just know it's a commitment !!
#58
#59
Captain Obvious
Super User
Super User
Can you post some better and more close up pictures of the IMS bearing? If it was an aftermarket unit, there should be a spacer to make up the difference between the stock bearing width and the aftermarket unit.
Take it all apart and have a good look how the engine looks like on the inside, then make a decision what to do. There are a few of us here that either rebuilt them or did extensive repairs to them. I have mine half way done and in the process off re assembling it...has been sitting idle while I finish another project.
#60
And the shop's word for that matter...That invoice is for all intents and purposes useless/meaningless!!! No parts prices, no labor prices nothing...There is no way in hell I would ever pay on an invoice like that...
