In search of a 3.4l case and pistons
Hi all,
I am finally getting around to having my 2000 C4 cab 3.4l motor rebuilt after a nasty intermix issue. (The head is cracked in two (!) places!) Upon teardown, it is apparent that I need a new case and pistons as one of the cylinders is scored and the associated piston is slightly damaged.
Please PM me if you have a case and pistons or know where one can be sourced. I would also consider a complete engine if it is in good condition. Incidentally, I will have at least one spare good head after the rebuild if anyone is interested.
Cheers,
TomF
Cheers,
TomF
My understanding is the cylinders are bored to 99mm (3.6) but the stock 3.4 crank is reused. But yea, please check with LN.
http://lnengineering.com/products/watercooled-cylinders-pistons/34-to-36-911-nickies-inc-99mm-fsr-je-piston-set-inc-rings-pins-clips.html
http://lnengineering.com/products/wa...ins-clips.html
Former Vendor
I have tons of good used pistons, but not any blocks.
Approach with care!
