IMS Bearing ALMOST failed
#31
- Double-row IMS: Engine #s up to 661 14164
- Single-row IMS: Engine #s from 661 14165
It seems that late '00s might be single-rows and 01's could be either without rimes or reasons.
#32
Former Vendor
If this can help but use with care: I made this note in my '00 996 document a few years ago from either a Rennlist or Renntech post:
#34
Former Vendor
Jake, would a magnetic drain oil plug pickup the IMS particles?
If a bearing has began to fail, the bearing has already failed as far as we are concerned. The engine will always see some sort of collateral damage from debris thats large enough for the eye to see, no matter how fine that may be. No, the factory oil filter will not remove all of this, especially with it's suck *** bypass design that bleeds oil by the filter at every cold start.
#35
I can't believe I missed this IMSB thread for 4 days. So some more questions.
With the case damage shown will the flange still seal and hold the assembly secure? How much damage to the cams, crank, etc? C'mon, more info.
#37
I stopped by the shop again today. The builder confirmed that the crank and camshafts were in excellent condition (they were fully inspected and measured) and are being reused. The cylinder heads were not damaged, but had to be completely disassembled for ultrasonic cleaning anyway, so they got a full rebuild. As I mentioned before, the original intermediate shaft will not be used, he'll be installing a new OEM NOS intermediate shaft. Virtually everything else is being replaced, and in some cases 997 parts are being used, such as the chain tensioners which were significantly upgraded for the 997 to include large springs that help ensure that there is tension before oil pressure builds.
He said the damage to the sealing surface for the IMS bearing cap is not a big problem, he can clean that up, and said he's actually worked with other blocks where this was in much worse condition and he was able to remediate it.
#38
"He said the damage to the sealing surface for the IMS bearing cap is not a big problem, he can clean that up, and said he's actually worked with other blocks where this was in much worse condition and he was able to remediate it."
That's good to hear! Did he mention how he plans to "remediate" it? Removal of material (i.e. grinding /machining) will create a sealing problem - afaik there are no oversized IMS flanges available... Maybe add material/weld and re-machine back to original spec.?
#39
#40
He should be happy to answer any question you have about the work so that you understand what is happening and how it will effect your engine in the long term. If not, then he isn't someone you want working on your car.
Certainly don't waste his time with simple stuff, but something like this is important and you need to be satisfied with his answer.
#41
If it was a shop I wasn't sure I could trust, I would want to know everything. In this case though, I'm working with a top tier builder, and he's happy to let me stop in any time. I went to him upon recommendation from the other German shop in town and local PCA club officers. Looking around the Internet, I've seen nothing but glowing reviews from everyone, including Charles Navarro of LN Engineering (who among many things also designed the IMS retrofit with Flat6).
#42
I get that. All I'm saying is that asking questions doesn't mean you don't trust them or anything like that. Just that you are interested in the process and results. Of course if you aren't, there's nothing wrong with that. I'm just super interested in that kind of stuff even if it's not something I could put into practice. How things work just fascinates me
#43
^Me too^ I didn't mean to come off like I didn't believe what they were doing, just trying to understand their process/techniques... I love the idea of fixing things instead of throwing them away and starting new - although I also understand that there is a time/place for that as well. There's just way too much of "that can't be fixed" type of attitude due to sheer laziness, incompetence or greed (or all three) for my comfort. Once again, best of luck with the motor!
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
