What is the total oil capacity for a 996?
#31
Don't shoot the messenger.
#32
More importantly, where does everyone store their empty DT40 bottles in their 996?....
#33
Jake Raby recommended in another thread to run BR30 for 500 miles as a flush oil before swapping into DT40. Another member on here was getting weird readings from an oil analysis after doing a straight switch to DT40. The results were reviewed by Lake Speed Jr. with Gibbs Racing and his opinion was it was due to the interaction of two very different oils.
#36
I have the LN 2qt deep sump(and The IMS Solution spin on filter) and it takes 10.5 quarts to hit the middle mark.
#37
I don't worry when it flashes because I know I have more than enough oil.
LOW=plenty when you have the 2qt deep sump.
1qt low...meh, I'm fine!
#40
Glad I read through this thread, looking to use DT40 and use the BR30 prior. I also plan on getting the used oil analyzed.
#41
Don't get too concerned on the initial UOA results, especially after changing oils, its the trends that show up over multiple UOA with the same oil that give a better picture of what’s going on inside the engine.
#42
I get you and def something to consider. I think the car has 3k miles on it's current oil change but since it's a new car to me, I'd like to get all the maintenance started and then log everything moving forward.
#43
Definitely do a UOA on oil that’s in the car now, didn’t mean to recommend not doing it. More data points the better. I’ve done 5 UOA (2 with mobil 1 and 3 with DT-40) covering 29k miles.
