Thought I hurt my engine, turns out I had too much oil
So I'm new around here and purchased a 2001 Carrera 4 6spd in the beginning of December. The car came to me with a major service having just been done which included an oil change. After a couple weeks of getting to know you driving I started to drive a little harder. After a particular quick right hand turn I scanned my mirror and saw the best James Bond smoke screen I have ever seen. My heart skipped a beat, then sank. The car ran good no bad noises or check engine lights and no smoke on light throttle. I pulled over while running checked the tail pipes, pushed the gas a little still no smoke. So long story short after some searching on here and elsewhere I've learned of the AOS problem and potential flair ups with too much oil. I checked mine and on the gauge it showed one bar below max so I was ignorant as to the real level because it was past the plastic end, in fact about 1/4" onto the wire. I'd have to guess two quarts over. Instead of messing around with trying to get the level down I just dumped it all and did an oil/filter change. Put 8qts in started it, then shut it down and check again. Took about 1/3qt more to put it about 1/8" from the full mark. My dash gauge reads two bars from the max, I don't trust it much anymore. It's good for a general use I suppose but I've learned for myself as well as from this board the dip stick rules. I have not had another occurrence of smoke since and believe me if it was going to do it, it would have especially after my drive through the local mountains on Saturday.
So when you drained the oil, you also replaced the new filter and it still only held 8 and 1/3 quarts? That's odd.
I did frequent oil/filter changes on mine and it always took more than 9 quarts. I would also let it drain for a long time before refilling.
Its important to keep the oil level at max for the IMSB's health because the seals are surely compromised by now if your on the original.
I'm honestly not that worried about getting every last drop of old oil out of it unless the filter has a bunch of junk in it or there is sluge. Reason being the 5000-5500 mile Mobile 1 oil I took out still looked like new, didn't smell, wasn't all that dirty, and would have easily been good for another few thousand miles. Then without a baffle, I'd personally rather run it a bit low than high.
Originally Posted by Chiamac
Going out on another limb and assuming KK is also a little high.
Lets give it a rest unless he does start back up again please.
My bad, I'll edit my post if you want to edit out my quote.
I thought it was a bit odd too because I fully expected to put 9qts in. Now that you all have brought up some good points, my driveway is slightly inclined, the car was backed in and the dip stick would have run towards the lowside if the engine because of the incline giving me a false reading. I may be low on oil now because I did not get a full reading, it was almost full. I'll check it hot on a level area and make sure to have the rest of my oil with me. The car did have the IMS upgrade done with the clutch about 15K miles ago so I feel it's in good shape but I would hate to harm it because of a bone head rooky mistake.
That makes for a interesting lap!
