Sunroof panel
Alcantara was coming off panel under sunroof, so I removed the panel and applied some spray adhesive which worked. Now I can not figure out how to reinstall panel. Does it slide in there or are there some fasteners that a) weren't in there previously, or b) I broke them when removing it. Panel came out very easily I did not have to force it.
From what I have read you need to manually wind the sunroof back all the way to get it into position. You can do this by removing the interior light and there is a manual sunroof override. Hope that helps!
As I recall there are some clips on the front edge of it that once the metal part is back, you then put the cover panel on it by sliding it backwards and there are some clips. I would look in the manual. It's been a while.
