996 Forum 1999-2005
Should I use thread locker?
Old 12-10-2015 | 09:24 PM
  #31
5CHN3LL's Avatar
5CHN3LL
Originally Posted by JayG
If you have any extra left, cover the water and oil drain plugs as well
I was attempting this DIY per your instructions, but I cannot find the oil drain plug. Please advise.
Old 12-10-2015 | 10:48 PM
  #32
gnat's Avatar
gnat
Originally Posted by Warehouse33.net
I wouldn't think any type thread-locker would be necessary on these bolts, but to be safe you could tack weld them like 5CHN3LL says. Maybe safety wire them first then tack weld? -Jason
Damn vendors! You're ruining this forum by running around pushing your safety wires! Nobody needs them. It's just a frivolous waste of money!
Old 12-11-2015 | 01:04 AM
  #33
JayG's Avatar
JayG
No problem, just cover the entire bottom of the engine
Now you do know where the engine is, right?
Old 12-11-2015 | 04:44 PM
  #34
Warehouse33.net's Avatar
Warehouse33.net
Former Vendor
This thread might need to be STICKIED at the top for future technical resources.
-Jason
Old 12-11-2015 | 06:10 PM
  #35
5CHN3LL's Avatar
5CHN3LL
It's in the front trunk, right? That flap on the right front fender where I add the water MUST be near the engine.
Old 12-11-2015 | 06:11 PM
  #36
5CHN3LL's Avatar
5CHN3LL
I kinda wish I hadn't welded the trunk shut, but it seemed like a good PM project. Oh well, nothing that can't be fixed with the plasma cutter...
Old 12-11-2015 | 07:14 PM
  #37
JayG's Avatar
JayG
Yes, thats it!
I hope you are only using distilled water. Tap water could lead to damage of the IMSB
And let's not make this a water thread
Old 12-11-2015 | 07:50 PM
  #38
gnat's Avatar
gnat
Wait! What?
I thought that was the filler for the unicorn semen tank!
Old 12-13-2015 | 02:01 AM
  #39
Water Hound's Avatar
Water Hound
Uh oh...
I thought it was for unicorn tears. I've thread locked, safety wired, tack welded and JB weld massaged everything. Have I made a mistake somewhere?
Old 12-13-2015 | 11:44 PM
  #40
JayG's Avatar
JayG
Yes, you need to thoroughly soak the brake pads and rotors with WD-40
Old 12-14-2015 | 02:59 PM
  #41
5CHN3LL's Avatar
5CHN3LL
If you let the pads wear down to the backing plate, you'll be able to tack weld the pads to the rotors. Admittedly, this results in a hit to acceleration, but your brakes will be solid.
Old 12-15-2015 | 01:10 PM
  #42
mcbit's Avatar
mcbit
This is too silly and requires a thread locker!
Old 12-15-2015 | 01:41 PM
  #43
5CHN3LL's Avatar
5CHN3LL
OP, this is where you say "blow me, a**holes" and lock the thread.*
*This is the Ireland variant of thread locking. There are other techniques, but the Ireland is a modern classic.
Quick Reply: Should I use thread locker?
