996 Forum 1999-2005
How to install OPT7 LED H7 low beams in a Porsche 996.2
Old 08-21-2017, 05:21 PM
DrMEMS
DrMEMS's Avatar
Originally Posted by Saintrey
Great job but just wondering instead of one big hole, can't you just drill a lot of smaller holes with a regular drill bit? Thanks!
An array of smaller holes would probably work as well, depending on the total area and where they were located.
Old 08-22-2017, 09:23 AM
rogazilla
rogazilla's Avatar
I bought a different brand Nineo on amazon and the heat sink and fan is wider but shorter. it leaves about 1/2 inch (estimate) behind the heat sink to the cover.
It seems like there is plenty of room in the housing to move air around and there is a little drain hole with 90 degree angle rubber hose on the back of the housing i figure can relief some heated air. I did not drill any hole on the housing and have not had any problem.
The surface of the light housing after driving 30 minutes at night is barely warm to the touch.
Old 08-22-2017, 12:10 PM
Saintrey
Saintrey's Avatar
Link please for the Nineo? Thanks!
Old 08-22-2017, 01:02 PM
wyovino
wyovino's Avatar
What is this part and where does it go? I looked on the Amazon site but I didn't see any instructions.
Old 08-22-2017, 01:43 PM
Sneaky Pete
Sneaky Pete's Avatar
Not post related......but what ever happened with your car?
Old 08-22-2017, 02:28 PM
rogazilla
rogazilla's Avatar
I stashed that part below the projector housing between the highbeam and the indicator light. There is plenty of space there to stash it. I assume the space was for the washer assembly which I don't have.
Link is here: http://a.co/j0o1tiY
I am not affiliated with the seller or the product in any way.
Note I did have to cut the holding ring as indicated at this thread to fit the bolb itself into the projector housing. I did buy additional rings and keeping them in the car just in case any time the bulb fails I can find a halogen and be home safely at night. Hope I never need to use it. The ring's part number is 996 631 128 00.
Old 12-15-2017, 06:05 PM
jdrake
jdrake's Avatar
Has anyone looked at replacement housings for LED lights in their 996? I came across this site the other day but know nothing about them.
https://www.cargym.com/product_info....oducts_id=2448
Old 01-04-2018, 09:26 PM
911STYL
911STYL's Avatar
Default Feedback
Did you ever get any feedback on this? These seem to kill multiple birds with one stone if they are genuinely plug n play. Steep price but again multi-functional, stylish, modern, updated and doesn't appear that they would have to be "made" to work. Let us know and I will do some research as well.
911STYL
Old 01-05-2018, 10:43 AM
jdrake
jdrake's Avatar
I have not been able to get any feedback on this company. I am still trying. I will keep this forum updated as to my progress.
Old 01-05-2018, 10:51 AM
cds72911
cds72911's Avatar
wyovino,
I think that is called a "driver" but I'm not sure of that.
The LED replacements I've had include the LED "bulb" with an attached fan assembly (some brands have heat sink ribbons) that plug into the factory housing, and that plugs into the driver, which plugs into the stock light harness.
The ones I used on my last couple of motorcycles (Cyclops brand) had very small drivers, roughly the size of a pack of gum. The cooling assembly attached to the bulb is pretty large though...
I think I still have one of the Cyclops LEDs from one of my KTMs, not sure if it is a H7, but let me look. If it is, I can test fit it to see if it fits in the space available in the back of the 996 housing.
Old 01-06-2018, 12:02 PM
RT_955TT_KY
RT_955TT_KY's Avatar
My 99 had the LED/halogen replacement headlight assemblies installed when I bought it. I wasn't a huge fan of the style, or the light output of the halogens. I replaced the projectors and bulbs with some HID replacements from The Retrofit Source and that greatly improved the light output. That being said, I finally found a decent set of original headlights at a great price and I'm now in the process of stripping them down and rebuilding with some custom HID projectors.
The build quality of the Chinese units is pretty poor, and they started to have issues with the switchback LED turn signal/parking lamps.
Chinese units
OEM units before upgrades
In process
I'll update as the build progresses.
Old 08-29-2022, 05:39 PM
tbrodeur421
tbrodeur421's Avatar
Default Best H7 LED Bulbs for 996.1/996.2 in 2022?
https://www.youtube.com/watch?v=5qoeCQbXGgs
Old 08-29-2022, 05:40 PM
tbrodeur421
Which modern day LED H7's can fit a 996.1 or 996.2 and be fully plug and play, not melt any plastic, not generate a canbus code and throw a strong but not blinding beam pattern?
So many choices I'm hoping someone has had success like this guy.
Quick Reply: How to install OPT7 LED H7 low beams in a Porsche 996.2
