Front Bumper Cover aero stuff - is it missing?
My '04 C2 Cab has these slots under the front bumper cover and evidence that there was something installed there. I found what appears to be the right piece for this in the parts diagram but it says it is for a C4S...??? So, should my car have some rubber "fins" or something attached to these slots? Is the parts diagram incorrect about the part being C4S only?
Just to clarify, I am talking about the narrow slots that are all the way across the front.
When I had the PPI done on this car they noted some rubber or plastic flow thing was missing in the front and this is the only place I can think of where it might have been. I hate unsolved mysteries so thanks for any help on this.
If you can get the PN, that would be fantastic. I just installed the center radiator exhaust vent, and that rubber is clearly intended to create a low pressure area in front of the outlets.
I found an item that looks like it could fit in these slots. It is p/n 996 575 161 01 but this is the part that is noted "C4S".
So do all 996s have these slots like mine? And doesn't anyone have a car with something fitted in this area? I am tempted to try to order this piece just to see if it will fit but there should be a more certain solution.
UPDATE Just found this on RennTech; http://www.renntech.org/forums/topic...-mistery-part/
