Vertex Auto and its Permanent IMSB Upgrade
Ok…..I’ve been on here for 8 years and still can’t figure how to multi-quote. I don’t get that technical but I sure read a lot. ….and after so many recent threads or endless threads about the IMS roller bearing vs ball bearing me gots some questions and comments….so I’ll put in italics the comment followed by my question.
1. "The intermediate shaft roller bearing design model developed by Vertex and used by Porsche for decades is now an over-engineered permanent upgrade essential to the life of your engine. "
Where has Porsche used a roller bearing for an intermediate shaft for decades? Yes, roller bearings were used in the 4 cam until they were replaced with plain bearings due to reliability problems with rollers. This was in regards to the crankshaft, never were they used for an intermediate shaft, right?
2. "Of course we warranty the part for 2 years or 20,000 against defect."
2 year warranty - why was this reduced from 5 years? The last issue of Excellence still shows the 5 year.
3. "We want to first apologize to you fellow Porsche owners, especially 996 enthusiast for not being present during many of the IMSB discussions on this board. Vertex made a conscious business decision to hold back on the internet presence until there were enough Eternal Fixes installed in 911s and Boxsters to appropriately respond with authority and in particular evidence about how well the Eternal Fix works. Even though our data and multiple experimental conditions provided our engineers with the evidence that the Eternal Fix would last the life of the engine, we needed real-world confirmation, customer experience, word of mouth, and dealer feedback to be established before we widened our internet presence."
I'm sure you are aware of the other discussion on roller bearings vs. ball bearings. A question I have in your ad it says 5 times the load capacity, where readily available and published load capacities would say it's much less than 5 times that of a ball bearing. Also, how do you address that ball bearings can carry more of their load as thrust than a roller bearing? I'd like to hear how you determined your patent pending thrust control works. You state that the design is Patent Pending, what is the filing number? I am sure that many here would like to review this application.
You’re competitor at MB Motorsports has a cool similar kit. What is the difference, and why is your’s better? Who copied who? Side note did I just give Martin a compliment?
Now, back to your regularly scheduled programming.
Pete: To multiquote, click on the little icon in the bottom right corner of the post you want to quote, the one with one quotation mark and a plus sign on top of the sheet of paper. If you hover over it, a message stating "Multi Quote" will pop up. Click that on every post you want to quote. Then go down to the bottom of the page and hit the "Post Reply" that's right above the "Similar Threads" and Tags listing. Took me until recently to figure it out also.
You can also click on the double quotes for the last one you want to include and that will open up the reply window
Interesting counterpoint on cylindrical bearing use for IMSB HERE.
But now we hear that LN is coming out with a cylindrical bearing anyhow??
How much thrust load is there on an Intermediate shaft in the first place? In other words, does a cylindrical bearing provide enough thrust control to account for the loads it sees in the engine, or not?
Looks interesting. They provide a boring tool to get it to fit the '06-'08 engines? Which means no motor disassembly? I have a late 997.1, so this thread has my attention.
So when the engine is running, you are feeding oil into the nose of the IMS shaft through your slotted hex key (an area that is a known failure point in the first place, seems slotting a key makes it weaker, but i'm not an engineer). How fast is the oil feeding in, and how fast can it get out of the tube when the engine is running? Is this going to affect the oil level to the rest of the engine as the tube fills with oil? As the engine sits turned off, how is that oil coming back out of the tube slowly going to affect your oil level readings? How much oil does an IMS tube hold? If that tube is full of oil all the time, how does it affect the inertia of the tubes rotation? Typically when we remove IMS bearings where oil has seeped past the seal, there is a bit of oil in the tube, but not a ton as it seems there would be with this product.
After watching that video....I don't see how they are keeping metal from falling inside the engine with this method....and the price of messing that procedure up would be catastrophic.
http://www.imsbearingsolution.com
A few years ago I read an article in one of the british magazines wherein one of the tuners over there had figured out a method to actually collapse the larger later-style bearing and then extracted the pieces from the case. This was before I actually bought my car so I didn't think about it too much at the time and now wish I could remember the magazine and/or the tuner. Could have been Hartech but not sure anymore. In any case, same questions, seems kind of risky but maybe I'm not aware of something.
Dead horse here https://rennlist.com/forums/996-foru...-to-watch.html
Uh, yeah, I'd love to know that answer as well. The video appears to be shot out of sequence but I don't see how this process will stop shavings from ending up inside the case.
