996 Forum 1999-2005
Doing my AOS
Old 08-11-2015 | 01:33 AM
Bmantdot's Avatar
Bmantdot
Default Doing my AOS
Last year I changed my MAF because of a pcode. So last month my water pumped failed so I did my water pump, belt, coil packs and spark plugs. Now my AOS needs doing. I have p0507, p1128, p1130.
So my question is while my mechanic is changing out the AOS what else should I have him do? Any recommendations?
Old 08-11-2015 | 01:50 AM
Ahsai's Avatar
Ahsai
If the tech is going to remove the left intake manifold, it's a good time to replace all the vacuum hoses and elbows, 2 change-over valves and the vacuum reservoir. The parts are about $150 if you get them from Sunset Porsche.
Old 08-11-2015 | 08:58 AM
dallison28's Avatar
dallison28
What ahsai said. I will probably do that this coming winter.
Old 08-11-2015 | 09:25 AM
DBJoe996's Avatar
DBJoe996
What Ahsai said and also, depending on mileage/age, while all that stuff is off the left side might consider a new coolant tank. I know it adds up but it will have to be done eventually anyway.
Old 08-11-2015 | 03:54 PM
Bmantdot's Avatar
Bmantdot
I appreciate all the input and suggestions. I figure if he's there already might as well have the tech do other stuff. Keep the suggestions coming! Thanks
Old 10-23-2015 | 03:57 PM
Youri Ko's Avatar
Youri Ko
My p1128 and p1130 were caused by clogged fuel return line. (See my other post)
I changed the AOS for nothing and glad I did not change anything besides that.
Check your fuel pressure!
Old 10-24-2015 | 08:22 AM
Hurdigurdiman's Avatar
Hurdigurdiman
Please explain 'clogged fuel return line'. How does a fuel line get blocked?????
Old 10-24-2015 | 11:23 AM
Youri Ko's Avatar
Youri Ko
See https://rennlist.com/forums/996-foru...related-3.html
Quick Reply: Doing my AOS
