00' 996 C2 to 05' Turbo brake upgrade
Does anyone have experience/advise on the right way to go about this brake upgrade?
I bought a set of used Red Brembo's off an 05 C4S Turbo 996 and need to figure out what bits I need to complete a successful upgrade...
New fluid/flush, Rotors, brakelines, pads, new bolts... what size/brands and what else while I'm at it?
Thanks in advance!
Thanks in advance!
Thanks David, any more details on what the wheel carrier should look like and how to purchase? Is this just for the fronts?
I heard mention somewhere of changing the "knuckles"...?
Surely you dont have to change out the entire carrier (item 1) ??? Isnt there an adapter of some kind?
http://www.autoatlanta.com/porsche-p...section=401-05
I poked around a bit more on this site and found this thread...
https://rennlist.com/forums/996-foru...kes-on-c2.html
Are there any alternatives... this sounds like a serious endeavor!
Thanks for your patience folks...
spindle assemblyI(hub/carrier). You will also have to replace the hard line section by the caliper. I'm slowly acquiring parts for it.
Thought about the 380mm versions but decided to stick to 350mm so I can run 18's.
