Setting Seat Memory to Key FOB
I think I may have a reading disorder, but I know I'm in good company...since no one I've asked (including the dealer) has been able to set the memory button on my seats to my key fob (WITH THE OWNERS MANUAL IN HAND!)
Has anyone been able to make it work? The previous owner must have been a genius circus midget, cause they got it work, and move the seat right up to the steering wheel, so I don't even bother to use the key fob to unlock the car.
Someone please help...
TIA
TIA
With the key in the ignition, hold the lock button and press the memory button at the same time. It's a bit of a contortion, but it works.
Put the car in reverse while doing this and the passenger side mirror will aim down towards the curb when backing up.
Here it is verbatim from the owner's manual (It's here at my desk and I type real fast like). This works for me in an '01 coupe.
1. Switch the ignition on with the desired vehicle key
2. Set the desired seat, lumbar and door-mirror position. If you wish for the passenger's mirror to swivel down as a parking aid when reversing, reverse gear must be engaged when the seat position is stored.
3. Keep memory button M depressed and press the central locking button on the remote control within 5 seconds. The individual setting is now assigned to this remote control.
Originally posted by 01 C4 Cab NYC
Random,
I swear I've tried this, but I'll give it another whirl...so press the M button or the '1' button, or both?
Random,
The number buttons don't have any interaction with the key as far as I know. Should work - I know a couple times I accidently pressed the luggage compartment button rather than the lock/unlock button.
Do you have the memory feature? It's 4 buttons (M, 1, 2, 3) located to the left of the driver's seats near the door sill. You won't miss them if they're there.
If they're there, it seems like it should work, but who knows (someone else with a '99 most likely ), maybe it's a function added in a '00 or '01?
All these electric gizmos - my last car didn't even have power windows. I just found out about 'The Comfort Feature'. On a hot day, unlock your car using the key (rather than the remote) and hold the key in the unlock position --the windows automatically roll down. Works in reverse too.
Kind of silly actually. My wife's Audi has this feature, only it opens all 4 windows plus the sunroof, which makes it at least a little less silly.
What I would love is if you could get the windows to roll down using the remote. Let the car air out a little as you walk up to it on a 100° day. And you probably know the trick to extend the range of the remote...stick the point of the key agains the bottom of your chin when pushing the button. Doubles the range at least - works with most any remote actually.
I've also tried it on my 2000 C4 coupe and it doesn't seem to work. Do the keys on the '01 and younger cars have two buttons? Mine has only one, that might be the reason why I can't get it to work. Also, does anyone know how to determine if you can unlock the trunk remotely on an '00?
