Went to change my pads and found this...
See broken part in this Front Left wheel well pic... assume it is a suspension stroke sensor, but what does it do, and more importantly, what is the consequence of driving it un-repaired?
The part it mounts to is plastic so it must have struck road debris I am guessing...
Thx!
Thx!
Received 1,166 Likes
Litronic light level adjustor. Just replace that piece of plastic and you will be good. I think it is Part No. 21 in this diagram...about $5.
http://www.autoatlanta.com/porsche-p...section=401-00
Try this, when the car is OFF, turn the headlight switch to the low beam position, then insert and turn the key to last position before cranking. Both lights should aim up and down to calibrate (have someone else to check or just shoot a video). If one of the lights does not, the servo is bad or it's not getting power.
Try this, when the car is OFF, turn the headlight switch to the low beam position, then insert and turn the key to last position before cranking. Both lights should aim up and down to calibrate (have someone else to check or just shoot a video). If one of the lights does not, the servo is bad or it's not getting power.[/QUOTE]
I just tried that on mine and it works. However I have never been of the opinion that the headlights are particularly bright or good or aimed far enough ahead, and have been wondering if others have the same issue? It's bad enough that on a dark country road at night I am usually not exceeding the speed limit as there is not enough visibility. My others cars, no problem. Are people replacing bulbs, as far as I know mine are original to the car. It's an '02 so I believe Xenons are standard, the headlights do have the little chrome cover thingy.
You're not alone. I also feel my lights are not getting enough range and my level sensors are not broken. I asked the dealer to check the aiming a few times and they found nothing wrong.
Short of retrofitting new set of projectors, the more cost effective(albeit not the most optimal) solution would be to get the 55w HID kits to fit.
Something like this:
http://www.ddmtuning.com/Products/UltraCanbusHID
Some members have actually taken their lights apart and sanded/polished the projector lenses to improve output. I've only seen pics so can't really comment on if this effort is worth it or not.
Basic Sponsor
Might find something under electrical here that'll help with the DIY replacement of the broken part. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Luccia
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
![](https://rennlist.com/forums/signaturepics/sigpic303_8.gif)
I'm also in agreement and think all 996 projectors are crap compared to some other OEM's out there. It's the less than stellar projector lenses themselves they use that are inferior.
Just for reference, how many OEM hid equipped cars have you driven before that? My mk1 hid seems weaker and less pronounced than BMW, Audi, VW, Acura/Honda, Mercedes I've driven before. My favorite was the Honda s2000 lights.
The case you're describing is from using high wattage bulbs on a non projector based housing usually. Regular HID's only take 35w and even the 55w aftermarket ones do not generate heat like the 55w halogen bulbs so there should be no issues.
I've had an e92 BMW which were weaker and also several Hondas and acuras and the 996.1 seemed to me at least to be superior in the distance I was able to see
