Went to change my pads and found this...
Somebody previous already yellowed a couple spots on my inside lenses from too hot bulbs, but the lights work great on my 996.1
My S class AMG has xenon that are by God DAYLIGHT next to anything else I've had though.
Try this, when the car is OFF, turn the headlight switch to the low beam position, then insert and turn the key to last position before cranking. Both lights should aim up and down to calibrate (have someone else to check or just shoot a video). If one of the lights does not, the servo is bad or it's not getting power.
I just tried that on mine and it works. However I have never been of the opinion that the headlights are particularly bright or good or aimed far enough ahead, and have been wondering if others have the same issue? It's bad enough that on a dark country road at night I am usually not exceeding the speed limit as there is not enough visibility. My others cars, no problem. Are people replacing bulbs, as far as I know mine are original to the car. It's an '02 so I believe Xenons are standard, the headlights do have the little chrome cover thingy.[/QUOTE]
I'm also in agreement and think all 996 projectors are crap compared to some other OEM's out there. It's the less than stellar projector lenses themselves they use that are inferior.
Short of retrofitting new set of projectors, the more cost effective(albeit not the most optimal) solution would be to get the 55w HID kits to fit.
Something like this:
http://www.ddmtuning.com/Products/UltraCanbusHID
Some members have actually taken their lights apart and sanded/polished the projector lenses to improve output. I've only seen pics so can't really comment on if this effort is worth it or not.
Anyone find any remedies for this? Why'd they make them like this...oh Zuffenhausen...or Stuttgart, wherever you were born.
Either a kit like 986 here: http://986forum.com/forums/diy-proje...ng-finish.html
Or another high quality projector like this: http://ddmtuning.com/Products/Projectors-H1-V3-Pair
Don't bother with any of the generic eBay crap projectors. The best ones will have specifications for LUX ratings as well as give any detailed description of the projection characteristics.
Or you can get OEM projectors from an S2000 for example and retrofit those, but it would involve more custom work.
One factor no one has mentioned which could affect HID performance is the age of the capsules, these are cars getting on up to 15 years old like mine, my HID headlights come on as soon as I start the car due to DRL set up in Canada, so I would imagine they have a lot more hours than the US cars.
I did notice when first getting the car 4 years ago they were not as bright as I expect them to be, I did a quick calculation and come to an estimate of how many hours the car was "on", it was getting on the range of HID capsules hit the drop-off point in brightness.
So I got a new pair of Philips HID capsules, brightness improved noticeably although not dramatically.
