DME Reset
DME Reset
I'm getting an engine exchange done in my 996 (to a slightly used 997 block).
What happens to the information stored by the DME when you do an engine exchange? Does it keep all the info (such as over revs) on the old engine and then append it with the info on the new engine? Does it reset? Or, does the new engine's DME info port over?
Unless someone reprograms it, the DME cannot tell one engine from another. It only sees the same sensors and actuators on the new engine. In other words, the old DME info on the engine will continue to be updated as if the engine was never replaced.
Former Vendor
But its imperative that when the new engine is installed that the ECU is cleared with a "handover" or whats sometimes called a "system reset".
If this isn't done, the adaptive and etc may have adjusted to the failing engine, and will enrich the new one in the same manner. That can cause issues.
When we install an engine, we perform a system reset before the new engine is even started the first time. We want the adaptation process to occur as fast as possible with the new engines and for none of the old fuel trim and etc to remain in the DME.
