996 Forum 1999-2005
help
Old Apr 22, 2015 | 01:28 PM
bruno9xx's Avatar
bruno9xx
8th Gear
Default help
Hello I live in France and I have a Porsche 996 (year 2003)
my car went of Floride , she is in France from 2010
but I have a problem the witness check is always alight and the message for to go to the garage. I am go in garage Porsche and the problem is a sensor on the gas tank , a sensor only for the US model and this sensor is welded on the tank ( not screwed) and the french solution is replacement of the tank 1720$ they can't cancel this anomaly
My question: do you know where this captor is situated on the gas tank and what are the colors of the electric cable
Thank you and excuse me for my american writing
Good road for you
Old Apr 23, 2015 | 12:33 AM
fpb111's Avatar
fpb111
Maybe the fuel vapor recovery system is the problem? There are two common problems that can cause symptoms like you describe, both are electrically controlled vacuum valves.
One is by the tank filler neck:
http://www.pelicanparts.com/techarti...Vent_Valve.htm
The other is called Regeneration Valve it is by the alternator in the engine compartment.
It is the more common problem.
http://www.ecstuning.com/ES2224255/
or
http://www.pelicanparts.com/cgi-bin/...10-129-53-M100
File Type: jpg
Old Apr 23, 2015 | 01:16 AM
Ahsai's Avatar
Ahsai
There's also part #21 here
http://www.autoatlanta.com/porsche-p...section=201-00
It will help if you can ask the shop for the part number of the part in question.
Old Apr 23, 2015 | 03:25 AM
bruno9xx's Avatar
bruno9xx
8th Gear
Thank you I try the 3 control but where is the regeneration valve, I don't see this on my car
Old Apr 23, 2015 | 06:01 AM
bruno9xx's Avatar
bruno9xx
8th Gear
an other question: if I find the problem and change the equipment, the witness check will go out or I must go to Porsche for a reset
Thank you
Old Apr 23, 2015 | 12:25 PM
5CHN3LL's Avatar
5CHN3LL
Would a RoW reflash eliminate this issue if the problem component is US-only? If so, that might be less expensive than running down parts.
Can anyone else with more knowledge of reflashing weigh in here?
Old Apr 23, 2015 | 12:58 PM
bruno9xx's Avatar
bruno9xx
8th Gear
@ 5CHN3LL: I don't undersdand all your message :-(
but I have find the regeneration valve , in france we have this generation valve and the fuel line vent valve
but we don't have the valve 21 whose Ahsai speak, and if the problems are come of these parts , the data processing system of Porsche would have recognised these defects I think that the problem comes of this parts
Thanks of yours next ideas
Old Apr 23, 2015 | 01:08 PM
5CHN3LL's Avatar
5CHN3LL
Le logiciel de la voiture est le rapport des détails pas nécessaire en France . Je posais les autres membres en cas de changement du logiciel à une version non - US éliminerait le problème sans avoir à remplacer les pièces .
Sorry for the terrible French - the best I could do with a year in college and Google Translate.
Old Apr 23, 2015 | 01:15 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
Je pense que vos compétences linguistiques en français sont bonnes !
That being said, it has been a long time since I studied French in high school!
Old Apr 23, 2015 | 01:22 PM
bruno9xx's Avatar
bruno9xx
8th Gear
@ 5CHN3LL : thanks but your French is top
me too : Google translate
Old Apr 23, 2015 | 01:32 PM
Ahsai's Avatar
Ahsai
Part 21 is the only valve that appears to attach to the gas tank. It's inserted into part 20, a foam piece that's attached to the gas tank.
Sounds like your check engine light (witness) is ON. Can you use a scanner to retrieve the actual error codes? Those may give us more clues.
Old Apr 23, 2015 | 01:38 PM
bruno9xx's Avatar
bruno9xx
8th Gear
yes, but in France at Porsche they have only a european version (grrrrrrrrrrrrrrr, in France it's the economic crisis ) if you invites me with my car in USA for delete this default I went
driving with the witness check it is not a problem but I think about an other default arrived I don't see the new warning
Old Apr 23, 2015 | 11:50 PM
fpb111's Avatar
fpb111
Maybe try to get one of these?
http://www.durametric.com/
Old Apr 24, 2015 | 03:31 AM
bruno9xx's Avatar
bruno9xx
8th Gear
Thank s
I think buy this system
Thank you and good road
Old Apr 24, 2015 | 03:52 AM
Ahsai's Avatar
Ahsai
Thank you
If it's a evap system fault and the problem is corrected, the check engine light should turn off automatically after a few drive cycles with no more faults detected.
Durametric is great but you can also try a generic OBDII scanner (much cheaper) and see what codes you can retrieve.
http://www.ebay.com/itm/Wifi-ELM327-...item4ae2caccb5
