996 Forum 1999-2005
Convertible Top Maintenance
Old Apr 17, 2015 | 03:01 AM
Rubik's Avatar
Rubik
Default Convertible Top Maintenance
Lately, after I start the car, the convertible top light in the cluster stays on for about a 1-2 seconds before it goes off. Also, last week one day, it didn't work but after I turned off the engine and tried again in a 3 min span it worked again. Here are my thoughts:
1. Is the top mechanism about to quit?
2. Can I do anything before it quits?
Any help would be appreciated.
Old Apr 17, 2015 | 08:33 AM
frisbee91's Avatar
frisbee91
Just a guess, but it's probably just a microswitch. The one in the e-brake handle base is the most likely to fail. This is an easy fix.
Old Apr 17, 2015 | 10:56 AM
fpb111's Avatar
fpb111
Do 2002s need to be parked with e brake on? I thought 2002 on could move top @ up to ~30mph?
Old Apr 17, 2015 | 12:01 PM
Rubik's Avatar
Rubik
They need to be parked with e brake on. But I'm more concerned about motor & hydrolics. Could the hydrolic oil be low or leaking?
Old Apr 17, 2015 | 01:18 PM
frisbee91's Avatar
frisbee91
If the hydraulic oil is low or leaking, I would expect the movement of the top to be slow or strained. It's easy enough to check the level if you are unsure.
http://www.pelicanparts.com/techarti..._Mechanism.htm
Old Apr 17, 2015 | 03:27 PM
Rubik's Avatar
Rubik
Awesome link dude! I'll check out the details later today. I just realized that my top has been operating loudly so maybe the oil is low.
Old Apr 17, 2015 | 10:05 PM
Rubik's Avatar
Rubik
Just read it, and know and behold, you won't see the hydrolic fluid level unless you open the damn thing's guts. I just have to figure out what grade hydrolic fluid it uses so I can have it ready before I open it. Any idea folks?
