996NB Wheel fitment?
Rears would just fit if you use the right tires and roll your fenders.
You may have to heat and bend your plastic wheel liner up front if you don't want full lock rubbing. Once again, depends on what tires you use as well.
Spacers with those widths? LOL
By right tires do you mean very short wheel walls or do I have to have stretched tires? I don't want to reduce performance. Thanks
235/40-18 or 225/40-18 to be safe but you'll have a little stretch.
315/30-18 or 305/30-18 to be safe but you'll have a little stretch.
Once again, different manufacturers have varying contact patches even though sizing is the same. Tire rack does publish contact patch info as well IIRC.
Dunno if your rears will clear your struts if you have stock ones.
Do you already have the wheels? If so mount one of the rears to get an idea about clearance. If you don't already have the wheels, get 11" instead. 12" is usually reserved for widebody models. Boutique wheel manufacturers do make 12" for NB so they'd be able to tell you with certainty which combos will work. Contact someone like CCW about it.
