Is it necessary to let off the clutch while popping the rev to match the lower gear? That is, instead of clutching to take out of gear, releasing clutch and popping the revs and then clutching again back in gear----can you just engage the clutch, come out of gear--keep the clutch engaged while popping the rev, keep clutch engaged while putting into lower gear.
Sorry if that's confusing.
I'm guessing you're putting a tiny tiny bit of wear on the throw-out bearing but is it really that big a deal?
sorry for the joke but this post feels like somebody who just rewatched fast and furious... as fun as those movies are, please don't use them as reference material for how to drive a car...
I've read somewhere, but don't recall where I read it. Double clutching was used for old Porsche transmissions, but it's not needed for modern day transmissions.
Edit: I remembered my source, it's from the book "Ultimate Speed Secrets".
Wow. Maybe I'm way off the mark here, but maybe you're making this a lot more difficult than it needs to be? Even with my lightweight flywheel, I've never seen the need to worry much about matching revs.
Let off gas, disengage clutch, change gears, engage clutch smoothly while progressively applying gas. Voila.
The former will minimize synchro wear (but slower) while the latter is good enough to rev match (but will still create some synchro wear). In either case, the throw out bearing wear is not the concern as it's cheaper and easier to fix compared to the synchros.
And yes, most here will tell you double clutching is not needed in modern transmissions.
I don't think it's needed either. It's just that you wear the synchros less if you double clutch correctly. Whether you care about that is up to you.
I know exactly what it is but I like doing it. It's fun to match the revs and have a really smooth deceleration. Sorry everyone else thinks it's not necessary. BTW, in our DE's it is necessary to demonstrate the skill before progressing beyond intermediate.
It makes putting it in the lower gear much easier, even with modern syncros. I worry about the sudden load on the transmission input shaft, but it has so little rotational inertia it's probably fine.
I had to learn on a delivery truck, so I do it for all cars now. Makes for smooth heel toe downshifts when you get it right!
I've not been to a DE, so that'll be a new one for me when I go.
I learned to drive on a manual and most of my cars have been manual, but have never had to do this before. It could easily be my own ignorance though.
You've got lots and lots of weekends before they'll ask you to demonstrate proficiency. If you match the revs right you don't even need to engage the clutch. If you don't you grind. I don't risk it!
I only do it because I was already used to doing it when driving my '74 BMW. My other reason to do it is to just show off because I have Tubi's but as others stated modern trannys with syncro's don't need to be double clutched.
One situation where it can come in handy is if your slave clutch cylinder starts failing, you can rev match and be able to change gears still. Had to do this once before.
Heel-toe and trail braking are a much better use of your feet than double-clutching. Doesn't the blip during heel-toe accomplish much the same re: synchros?
