Secondary Air Pump
Secondary Air Pump
Anyone replace theirs? Mine is screwing up the idle after being warmed up and then stopping (coming off an interstate ramp to a stop). You can hear the fan come on, the idle pops up to near 1000 rpms and, eventually, the CEL comes on.
This started after the IMS/clutch replacement engine drop. My Indy found a split vacuum hose and he thought that cured it.
Ideas?
TC
Ideas?
TC
Give it a shot. I did it, but it only extended it's useful life by a few months. It may have already been too far gone. You'll see - it's fairly easy to get out. I think I got my new one for $270 at Pelican.
R
R
'04 and Pelican has them for $280. It just kind of sits up there in front--looks really easy to get to. I almost think it's a trap.
TC
TC
Ideas?
TC
Ideas?
TC
Ideas?
TC
Ideas?
TC
Seems like further investigation is needed - I don't think a failing pump would impact idle that drastically. It could be part of the solution for sure, but appears that there may be a second vacuum leak or related failure.
Code P0507 "Idle air control system higher than expected".
Like I said, you can hear the fan kick on and the revs fluctuate once you come to a stop. I'm not at all convinced it's a fan problem. It seems like it's something requesting the idle to kick up after harder driving when it's not necessary.
Off to the Indy when I get a chance.
Thanks all!
TC
Thanks all!
TC
Thanks all!
TC
Thanks all!
TC
which is consistent with air leak in the SAI vacuum control.
P0507 could be due to air leak https://rennlist.com/forums/996-foru...cel-p0507.html
Thanks!
TC
Replacing all the vacuum lines with modern tubing is a great way to eliminate gremlins. Not a very difficult job either. The original lines get brittle and crack and the cracks are so small there is no visible clue that they are leaking.
