Car won't start. Not getting 12v power to starter solenoid
#137
#139
Re-check your connection at the immobilizer antenna (plastic ring around the key cylinder) and the signal convertor ( black box mounted on the steering lock).. make sure they are properly seated. Wiggle them while trying to start.. Did you have these disconnected while doing your ign switch? Seems likely it's something to do with the ign switch replacement, and these are in the area...
#140
