Winter / salt / rust - how best to take care of the car?
peterp (12-18-2022)
As previously mentioned, these cars are very well protected against corrosion. Germany has winter too.....
My routine for all of my cars is to regularly run them through a TOUCHLESS (not the whirling scratching brushes) carwash that has a good underbody spray, especially after it has snowed. When time and temperature allows, I wash them in my garage with a rinseless wash (Optimum No Rinse). I give them a full spring clean with a scrub of the wheel wells, polish/wax, etc.
My thoughts exactly
Frankly it would seem wrong to drive one in winter.
In my search I've completely ignored cars that were exposed to a northern winter (road salt / extreme cold etc...)
Winter driving is what winter beaters are for.
just my opinion
Will
just my opinion
Will
Well, I respect your opinion - it can make sense to make some sacrifices in order to take care of the car.
My view: it would seem wrong not to drive it every chance I get!
That's reason enough for me. What's more, winter provides some driving thrills that summer can't.
(There's also a view, expressed elsewhere in this forum, that letting the car sit all winter causes it's own problems.)
peterp (12-18-2022)
I have never taken one of my German cars through a carwash. I always prefered to wash it myself. The idea of the undercarriage spray to clean salt away that is difficult to get to makes sense. It seems though that I read a Car and Driver article one time where they damaged the 996 in an automatic car wash. Maybe the rails are too high or the stop plate too high???
When I was a kid I lived back east just outside of Boston. We had what my dad called the good car and a beater that we drove in bad weather and the winter snow. The good car stayed in the garage during bad weather and when the roads were salted but we always had a blast driving the beater car. I'm pretty sure that if my dad had a Porsche it would have been in the garage during the winter. I been lucky to live in Vegas or southern california as far as weather goes so my cars stay cherry and I get to ride my bikes year round.
And BAD.TAG, really just the threads of screws? I mean, what you wrote seems entirely clear. I just wouldn't have thought these were the only parts that need protection, nor the most valuable - but then if I were sure I knew much about rust protection, I wouldn't have started this thread ...
I'm looking at it from a "should I ever need to get this loose" point of view, but I'm sure you could broaden the application as you see fit. Its a bit thick for moving parts like latches though, as I noted.
If you think of something else that would make sense, post it =)
let it snow...
no one has posted here for a long time but the issue still remains. I have two cars - 991 and 964 so one of them has to be driven in the NE winters with lots of snow, potholes and yes, salt. 964 has never seen snow nor rain ( in my possession, can't speak for her first 24 years of life) so its the 991.1 that gets winter duty. I know this is taboo for many but I won't give up one of the 911's for a winter beater though that would make a lot of sense.
So how do you guys get to the under carriage ? Do you have the car lifted and sprayed clean or relying on some on the ground system you can drive over ? The local car wash has some "under carriage spray" but I've never taken any porsche through the regular wash - they've always been hand washed by me or others. Problem is, I don't know how to get under the car- I suppose I could jack it up and put her on jack stands ? Then again, I won't be able to have water during the winter time. HELP !!!?!
I live where winters are long and roads get heavily salted. A good trick is to put a lawn sprinkler under the vehicle and let it run for a half hour or so. But, salt is a killer even if you try to wash it off. My 911 stays in the garage in the winter.
You should use a pressure washer, rid your car’s exterior of brine deposits through regular bursts of water with mild detergent without scratching. And you also need to repeat wiping until the surface is without any salt stain and shows glow. For the undercarriage, spray it profusely as well.
GC996 (12-12-2022)
Must haves
Old thread but, undercarriage wands
and a quality former should be in everyone’s toy chest.
