996 Forum 1999-2005
Upgraded idle pulleys
Old 01-06-2015 | 08:41 PM
Ahsai's Avatar
Ahsai
Default Upgraded idle pulleys
Just to let you know that all of our 3 pulleys have been upgraded to composite material ones with the following part numbers. They are MUCH lighter..~1/2 of the stock metal ones. I just installed them and they fit fine.
http://www.autoatlanta.com/porsche-p...section=101-10
99710211700 (the one on the belt tensioner)
99710211800 (the one the alternator long bolt)
99710211900 (the lower one directly bolt onto the engine block)
Name:  1220140904c (Large).jpg
Old 01-06-2015 | 10:33 PM
Byprodriver's Avatar
Byprodriver
Thanks for posting, I have been wanting to try this!
Old 01-06-2015 | 10:37 PM
Ahsai's Avatar
Ahsai
I weighed the new and old pulleys. You'll shave about 1 lb off the rear of the car for 3 pulleys
I felt my engine revs more free after....probably due to my new intake air filter though haha
Old 01-06-2015 | 10:41 PM
Byprodriver
Nice, can you share source & costs?
Old 01-06-2015 | 11:13 PM
Ck986's Avatar
Ck986
I can't believe how inexpensive the 996 pulleys are. I'm pricing out replacing my idler rollers and tension pulley for my 996tt at 520$ where as you guys are out about 200$.
Old 01-06-2015 | 11:28 PM
Gator996's Avatar
Gator996
Is weight savings the big advantage of these?
Old 01-06-2015 | 11:50 PM
Ahsai's Avatar
Ahsai
You can get them from www.porschepartshub.com for $70-80 each plus shipping.
Old 01-06-2015 | 11:55 PM
Ahsai's Avatar
Ahsai
I think the lighter weight puts less parasitic load on the serpentine belt and the engine (when the rpm changes) so that's a good thing. Kinda like light weight flywheel makes the engine more free revving but at a much smaller scale. As long as the composite material lasts longer than the bearing itself, everything should be good.
Old 01-07-2015 | 01:56 PM
Byprodriver
Yes, that is the main advantage.
Old 01-07-2015 | 02:04 PM
Schnell Gelb's Avatar
Schnell Gelb
There must be an Interchange for some of these to a generic part ? The alternator pulley is Bosch-compatible so that is a good candidate.I suspect the EBay photos are just low-res file photos so it is misleading to rely on them ?
http://www.ebay.com/itm/Porsche-987-...12532f&vxp=mtr
The tensioner -same?
http://www.ebay.com/itm/Porsche-987-...1ce327&vxp=mtr
Old 01-07-2015 | 02:19 PM
alpine003's Avatar
alpine003
It's very negligible in real world although it is sound reasoning in theory. Even tests have been done between heavier and lighter underdrive crank pulleys on the m96 with very little to no difference. The OEM GT3 crank pulley is lighter but mainly just to squeeze out every ounce of performance as to not leave anything left on the table.
Old 01-07-2015 | 02:20 PM
Ahsai's Avatar
Ahsai
I know of no OEM equivalent of these pulleys and yes, the eBay link ones show the same. You can get them for similar price from Porsche dealers like Sunset (www.porschepartshub.com) or ECStuning.
If you want to save money, you can press out and replace the bearings with the bearings of your choice. Those are std size bearings. I've read stories ppl replacing those with Chinese $20 bearings just to find the pulleys fail in 10k miles or so... However, if you choose a quality bearing with the proper spec, I don't see why they won't last as long as OE ones. However, such bearings will cost like $30~40 I think.
Old 01-07-2015 | 02:23 PM
Ahsai's Avatar
Ahsai
Agreed so I'm not claiming any hp gain
I replaced mine because mine were all very scratchy. It happens there was some confusion whether there's an updated version of these pulleys (diff sources said diff things) so I just want to confirm these are indeed designed for 996s and they fit well.
Old 01-07-2015 | 03:31 PM
alpine003's Avatar
alpine003
This is one of those PM's I'm actually in favor of due to a previous bad experience with a seized pulley that did a lot more collateral damage than it should've on another car.
Old 01-07-2015 | 03:36 PM
Byprodriver
Isn't that why we are all here?
