just installed 997.1 lobsters on 996.1 C2
They look pretty good to me. Scored them with better than 50% tires for cheap too! Pretty decent condition - no curbs, and just a few minor scratches here and there.
The rears are 19x11 with 295 P Zero Rosso tires. ET67
They barely hit part of the inner fender, which I trimmed for clearance.
The drivers side is sitting very close to this support beam looking thing. No problems with control arm - plenty of room there. I will probably put on 7mm spacers front and rear to push them out just a bit. But they would probably work OK as is.
Currently installed w/ no spacers.
Car is a '99 C2.
Car is a '99 C2.
Nice. Looks updated.
I wouldn't say you need to add spacers for appearance sake on the rear though.
If it helps you clear suspension components, that would be a valid reason.
Be careful of further fender/tire clearance problems though, particularly when the suspension compresses.
And I took it up a windy mountain road and pushed it hard. So it may be OK as is. I will drive it for a week and keep watching that and see how it's doing. For sure with 285/30/19s it would clear and not need spacers. Depending on what tire I go with when these wear out, I will probably go that route just to free up some space in there. I think Pilot SS come in that size, which is my go-to tire.
Fronts could easily take a 7mm spacer to make the stance / track just right, but it's not bad the way it is. And nothing comes close to hitting anything on the front either - not even at full lock going over the edge of a mountain road - tested that out when turning around
Forks folks, not claws. Lobster "forks".
They look nice, BTW. You might want to consider rolling your fenders. You can DIY, just search for posts on the topic. You'll just need a heat source. The very top of my fenders are rolled for clearance as my car was lowered by the previous owner.
Forks folks, not claws. Lobster "forks". They look nice, BTW. You might want to consider rolling your fenders. You can DIY, just search for posts on the topic. You'll just need a heat source. The very top of my fenders are rolled for clearance as my car was lowered by the previous owner.
Forks. But ya me too. I wasn't sure about these as I think there are better looking wheels on the 997 cars. But they were cheap so I figured hey why not give it a try. And it looks way better than I imagined on my lowly 996.1 C2!!
