Help Identify Object Blocking Exhaust
haha...i don't want that guy anywhere near my car.
So even though my cats are mk1 gt3 parts, the internals have been completely modified by ruf to be 100 cell. Spoke with ruf and will need to send to germany for a proper rebuild.
In the meantime, i'm planning on going with a cat bypass xpipe for a temporary solution.
Well unless you don't have to worry about emissions in your area or future resale, 200 cell cats will do a better job of filtering, less chance of CEL light coming on, and will only be marginally more in cost to the 100. 100's almost always sets off CEL's in our finicky systems unless O2 extenders are used. In Germany where RUF comes from, 100 cell cats may not be a problem over there. Also their ECU's have different operating parameters over there.
I don't have to worry about that since the car has had the 100 cell from factory since new. Has never thrown a CEL and passes inspection without issue. As for resale, i think rebuilding them to their original specifications is better than making modifications. Hopefully wont need to sell for a long time if ever.
Aftermarket usually only consists of 1 cat elements on each bank and is 100 or 200.
I don't know what your readings are but 100cpsi elements are illegal in some areas since they can't meet emission requirements.
Hmmm, not really sure I understand. The factory cats have 2 sets of cat elements on each bank and they are closer to 400cpsi.
I'm not sure if RUF was specifically built for the US market or came over as a gray market item from certain resellers. All I know is their products would've been technically illegal to sell in some areas.
Either way if 100 elements works for you, more power to you.
Is it even cost effective to get them rebuilt over there? Or do you want to stick to the RUF brand?
