996 Forum 1999-2005
Adjustable tie rods
Old Oct 11, 2014 | 03:50 PM
MiamiC70's Avatar
MiamiC70
Default Adjustable tie rods
Adjustable tie rods, point me in the right direction.
car is mainly DD looking for rears that will give me more alignment adjustability with my current x74 suspension. Not sure I need the big buck full racing ones but open to ideas.
Thanks in advance
Old Oct 11, 2014 | 04:26 PM
jj1's Avatar
jj1
Why do you need them? Are you looking for bump steer adj or just toe adj? Maybe you mean adj control arms?
Old Oct 11, 2014 | 04:30 PM
Ahsai's Avatar
Ahsai
I'm also curious about what jj1 asked as I also have x74.
Old Oct 11, 2014 | 04:38 PM
MiamiC70's Avatar
MiamiC70
Yes, rear toe adjustment.
Old Oct 11, 2014 | 04:45 PM
jj1's Avatar
jj1
How are you limited now? I'm pretty new to this platform, but it seems unusual that a small drop would limit your toe adj unless you were dialing in some crazy amount of toe.
Old Oct 11, 2014 | 05:48 PM
peteb3's Avatar
peteb3
RSS ones are great
Get them direct or through sharkwerks
I just put them on my ride
Old Oct 11, 2014 | 06:31 PM
MiamiC70's Avatar
MiamiC70
Originally Posted by peteb3
RSS ones are great
Yes, they are buy also $750 for rear kit
Old Oct 11, 2014 | 06:44 PM
jj1's Avatar
jj1
Looks like they are $500, but what are they going to do for you? Only good if you want to adj the toe curve not the static toe. If this isn't for track use seems like a waste of money. Am I missing something?
http://rss.rpmware.com/rss/rss_adjus.../i-398286.aspx
Old Oct 11, 2014 | 06:47 PM
jj1's Avatar
jj1
Also, measuring/ adj bump steer is probably $500 in labor anyways.
Old Oct 11, 2014 | 06:58 PM
MiamiC70's Avatar
MiamiC70
The OEM eccentric bolt and washer on passenger rear not giving enough adjustment alignment guy and my indy both agree easiest solution is to just buy an adjustable rear toe tie rod and be done with it. Just looking for options.
Old Oct 11, 2014 | 07:49 PM
peteb3's Avatar
peteb3
I had same problem
Expensive yes but well worth it
Adjustability plus you can feel the difference
Rear end fells really planted and solid under load now
I got both dog bones and toe kit
Old Oct 11, 2014 | 08:47 PM
MiamiC70's Avatar
MiamiC70
What brand did you end up with Pete?
Old Oct 11, 2014 | 10:10 PM
peteb3's Avatar
peteb3
Per my previous reply to your thread I used RSS pieces
Great quality
Old Oct 12, 2014 | 02:17 PM
trendy996's Avatar
trendy996
Torque solutions is probably the cheapest
Old Oct 12, 2014 | 02:30 PM
MiamiC70's Avatar
MiamiC70
Yep, I think that is direction i am going to go in.
