Adjustable tie rods
MiamiC70
Do you have the actual toe numbers available? I'm planning on lowering my car (likely a bit lower than yours). I was going to get GT3 CAs also. But if I *have* to buy toe links too, than I'd rather get the RSS arms and toe links to correct roll center and dynamic toe. That's why I'm very curious about your situation. Do you think it's possible you have bad bushings creating a problem in adjustment or is this a common problem I'm not familiar with? Any info helps.
Thanks!
JJ
Thanks!
JJ
I think I posted them on here before if you search my user name but I'll post them later tonight.
Here is what I think I am going to get to resolve the issue.
http://www.rennline.com/Eccentric-Lo...oductinfo/S40/
http://www.torquesolution.com/product-p/ts-por-002.htm
