Radio/CD issues
Here goes: just bought a 1999 911. Same radio as the boxster (base Becker 220).
Radio works fine - no issues. When I put a cd in the slot it plays just fine. Volume works but if you try to change to another track (turning the right *** or pushing it in) it freezes up all controls and the CD player keeps playing. You can't control anything at that point and it just keeps playing at the volume you set, even if the car is turned off. The only way to get it to quit playing is to restart the car and then the volume works again. You can then reject the cd and your back in business. Happens every time you hit the right *** with a cd in. Real pain in the ........
Any ideas from the best forum anywhere.
May just need to replace the radio.
