996 Forum 1999-2005
Seat Back Insert
Old Sep 19, 2014 | 06:32 PM
CrossT's Avatar
CrossT
Default Seat Back Insert
The seat back insert on my 99 996 is coming apart. Specifically, there is black fabric on the back side of the insert and this is tearing. This is causing the top to come loose. Not a big deal, but it doesn't look so good. How does the seat come apart so that I can have this repaired?
Here is a pict.
Todd 99 996
File Type: jpg
Old Sep 20, 2014 | 01:40 AM
fpb111's Avatar
fpb111
The center section lifts up to unhook it and fold it down on to the squab. That should let you see what is going on and maybe fix it without having to strip the seat.
This pic is from the web. The back is folded forward onto the cushion.
File Type: jpg
Old Sep 20, 2014 | 01:41 AM
dgjks6's Avatar
dgjks6
That's the only easy repair on the seat. It attaches with a clip on the bottom and a clip behind the top. If you grab that piece and lift it straight up it and then pull it, out it will unhook the back clips.
I bet when you do this you problem may be it is just not clipped on both sides. If the fabric is torn I bet you can find one on ebay cheap. There are lots out there because they don't wear. If it is heated there will be a power cord which you will have to unclip.
If that not enough instruction let me know. I have an extra seat in the basement I can take pics of and show you
Old Sep 20, 2014 | 05:21 AM
CrossT's Avatar
CrossT
Thanks guys!
Todd
99 Coupe
