996 Forum 1999-2005
adjusting 996 cabrio window.
Old Sep 17, 2014 | 02:17 AM
sstrickstein's Avatar
sstrickstein
Default adjusting 996 cabrio window.
I replaced my wife's window regulator today and now the window won't go down all the way. About 1" shows above the seal. How is this adjusted?
Old Sep 17, 2014 | 09:37 AM
Zenski's Avatar
Zenski
You need to remove the upper stop on the regulator. It's designed for a boxster and a 911. I had this happen to me last year and thanks to the forum it's a easy fix.
Old Sep 17, 2014 | 09:41 AM
fpb111's Avatar
fpb111
Take out the "Boxster" stop on the regulator.
http://www.kevinlaird.com/window.html
https://rennlist.com/forums/996-foru...w-problem.html
"With the door panel removed, bring the window down to about four inches higher than the door. Look at the left side of the regulator where the window clamps in. There is an adjustment screw to lower and raise the window, There is also a stop when the window is opened all the way. You will probable see another stop ~2 inches above the bottom stop which will cause the window to not open all the way. Remove that stop."
Old Sep 17, 2014 | 12:50 PM
sstrickstein
Can the clip be removed from the lower access adjusting holes in the bottom of the door
Old Sep 17, 2014 | 09:03 PM
fpb111's Avatar
fpb111
No, look at the 4th picture in
he is pointing to where the Boxster stop is/was mounted.
Old Sep 18, 2014 | 02:06 AM
sstrickstein
So I looked up into the door from below at the adjusting holes. The stop you speak of is on the forward rail of the regulator. I can see both stops from below. How is this stop removed. Is it screwed into the regulator or just clipped on. If its clipped on I can crack it off without damaging the regulator without pulling the door apart again. If its screwed in I have to remove the door panel to access. Does anyone have experience?
Old Sep 18, 2014 | 09:44 AM
Zenski's Avatar
Zenski
you will need to remove the regulator and unscrew it. I don't think you can do it with it in.
