pending 30K service
Well, I mean you have to do what you believe is best for you and your car, but unless the water pump is showing signs of distress were I you I'd leave it be.
'course, I'm a firm believer in the if it ain't broke don't fix it.
The same goes for the coolant tank, etc. (I would probably replace the coolant cap if it was an older version.)
Also if the anti-freeze was original I would have that replaced. I am a firm believer in a coolant drain and refill with fresh anti-freeze blend every 4 or 5 years. One reason why the water pump in my 02 Boxster lasted 172K miles.
Yes, do it and use OEM. Your pump is 10yrs old and a known issue on a 996. Just replaced mine on a 45k car, they can fail without a lot of warning. It's not big money or effort.
I would generally agree if it's not broke, don't fix it - but this is just insurance in my opinion.
Received 5,404 Likes
Yes, replace the water pump with an OE Porsche part. Flush coolant, and replace the thermostat and gaskets.
I just did the IMS, RMS, clutch, as I was jacking up the car (32,000 miles, 12 years old, I just bought it.) the pump started weeping! The first sign was right then! So I pulled it and the blades had started to contact the block showing some friction wear, but not loss of blade fins. I caught it just in time. I replaced it with a Porsche part. Not a bad job at all with all of the good resources out there. I also replaced the thermostat while I was in there of course.
