How many 996 owners work on their cars?
I am comfortable in the routine maintenance world (oil change, brakes, anything else that's accessible) but for repairs I'm more comfortable having my brother work on it since he is a gear head. But for things that really need an expert not to screw things up like IMSB, RMS, etc., I'll go to a specialist and write a check. There was a thread earlier of a guy who tried to do his own IMSB and has to basically give away the car since he screwed it up. I know my limitations and the risks I'm willing to take.
Replace targa top motors? Here's a signed check. You fill in the number you think is the right amount.
Unfortunately i have to do my water pump after it spewed coolant all over the place yesterday. Gonna order the part tomorrow and do the work this weekend.
I hate when my car is laid up.
But stuff like clutch im paying the pros
On the 996, I have repaired/replaced/installed: Water pump * Lube/oil/filter * Ignition switch * GT3 console delete * MAF * Brake pads and rotors * Brake system flush * Cooling system flush * Aftermarket tail lights * AUX input formPorsche stereo * Harness mounting bar (connects @ b pillar seat belt shoulder hard points) * RWD conversion * Under drive pulley * Spin-on filter adapter * WEVO semisolid motor mounts * rear seat deletes * hard wired radar detector w/ rear view mirror mount.
I do most of the serious stuff myself, like painting the calipers and refilling the washer fluid.
Actually I'm kinda ashamed I haven't done more, been in transit but me and the girlfriend just bought a house with 3 car garage . Ya hoo
Edit: Found it. I'm not worried anymore. Looks like they tried to do it without following a couple pretty basic procedures, like removing the tensioners and locking the cam. Oops.
Adding to the thread - yeah, I do just about everything myself. The only thing I don't do is weld. The 996 is relatively new to me but on the old 951s, I did everything from oil changes to the dreaded clutch job (which actually is way easier if you just pull the whole engine!!)
I've done most of the maintenance stuff and minor upgrades, but I've had my indie do the heavy lifting (suspension, ISMB, clutch) but unfortunately he passed away very recently. I'm thinking about buying a lift and doing whatever myself.
RIP, Harry.
RIP, Harry.
So far on the 996 everything up to/including IMSB replacement. Bought a Max-Jax* for IMSB replacement ease. Great lift for folks with small, low overhead, garages.
*http://www.bestbuyautoequipment.com/...FUoS7Aod7mkAPg
I've had my 2000 Carrera since last December. Bought it with 82K miles. Things I have done in my garage since purchasing the car:
Install ROW M030 suspension (sway bars, springs, shocks)
Water pump
Thermostat
Spark plugs and tubes
Engine oil and filter
Air filters
Fuel filter
I've taken the car to a shop for alignment.
So, I'm pretty much a DIYer. Had a 986 for a while. A few years ago it showed me a code saying something was amiss with the Variocam. I took the car to a shop to deal with that issue.
Water pump
Thermostat
Air filters
Fuel filter
ignition switch(ouch), oil, magnetic plug, oil & air filters, oil pressure sending unit(ouch), clean radiators, battery, tranny fluid, motor mounts, all done & maintained by myself. water pump & new belt put on by my indy. initial go thru, brakes, all fluids, sump plate, flush, done by the PPI guy. I've kept a Harley running for 14 years for most things, same with this car, however this car can HURT to work on!
Great thing about DIYing is you save money even when you buy the right tools for the job.
For the tranny http://www.harborfreight.com/800-lb-...ack-69685.html
For the motor http://www.harborfreight.com/500-lb-...730-10041.html
Used in tandom it made my life easy.
