Rattle from bellhousing only when warm
Former Vendor
Have you made sure the water pump isn't failing? These engines transmit sounds across them all the time. More than once I have had a water pump sound like the noise was coming from the bell housing.
Pull the belt next time it's warm and making the noise, then see how it responds.
