996 Forum 1999-2005
Why so squeaky?
Old Aug 7, 2014 | 08:25 PM
Gator996's Avatar
Gator996
Default Why so squeaky?
I swear, this car is gonna drive me to the asylum. One step forward then two back. Ok, 99 has the coveted ROW 30 suspension. Love it and it's been flawless. I installed a tecquipment roll bar recently and now the suspension is squeaking when turning. WTF? Totally new symptom. What has this roll bar done to my car? Too stiff?
This is more of a rant than a help me post since the answer is probably going to force me to donate plasma and sperm for parts cash.
Old Aug 7, 2014 | 08:33 PM
sjg1138's Avatar
sjg1138
Are you sure the squeak is coming from the suspension? Could be steering etc. Can the noise be reproduced while at a standstill? Easier to diagnosis if so.
Old Aug 7, 2014 | 08:37 PM
Gator996's Avatar
Gator996
Good call and yes, only steering come to think of it.
Old Aug 7, 2014 | 09:29 PM
nismosd's Avatar
nismosd
I would first check for any binding with the end links. Did you use stock end links? You could always take the bars off and see if that fixes the squeaking. They are pretty quick and easy to swap without throwing parts at it.
Old Aug 7, 2014 | 09:47 PM
Gator996's Avatar
Gator996
The ROW30 was Porsche installed and has been on the car for years. I am trying to correlate the steering squeak suddenness with the roll bar install.
Old Aug 7, 2014 | 10:18 PM
pontifex4's Avatar
pontifex4
Are the bolts holding the bar tight?
Old Aug 8, 2014 | 10:07 AM
DBJoe996's Avatar
DBJoe996
First rule of mechanics - always go back to the last thing you did. You installed the roll bar and now it squeaks. Remove the roll bar completely and see if the squeak goes away. If so, put some silicone grease on the roll bar attachment points and bushings when you put it back on. If the squeak is still there with the roll bar removed, then some other part of the suspension or steering rack needs to be checked.
Old Aug 8, 2014 | 11:29 AM
Sneaky Pete's Avatar
Sneaky Pete
Are the bushing for the new sway the proper size? Are they new?
Old Aug 8, 2014 | 05:14 PM
alpine003's Avatar
alpine003
It could be that the roll bar tightened up the chassis ever so slightly where your bushings for the steering rack bracket is binding just enough to squeak. IIRC, you have a '99 C2 which has slightly less stiff frame, especially in the front tub area than the c4 and mk2 models. Maybe loosen and remove steering rack bushing one at a time and lube it with heavy duty marine lube(or the same stuff they use on swaybar bushings).
Old Oct 1, 2014 | 07:45 PM
Gator996's Avatar
Gator996
Resurrecting my own thread. I haven't had time to dig into the squeak. Alps, are the bushings you mention easy to get to? I will see if I can find a diagram.
Old Oct 2, 2014 | 10:14 AM
mharrison's Avatar
mharrison
Do you have any polyurethane bushings? The major complaint when using polyurethane bushings is squeak.
Old Oct 2, 2014 | 10:33 AM
alpine003's Avatar
alpine003
Honestly I never tried on a 996 model. You may want to spray some lubricant in the area first to see if it changes anything.
Old Oct 2, 2014 | 11:11 AM
Gator996's Avatar
Gator996
That's the plan tonight. Research also points to lower control arm bushings. I will report back in the morning.
Old Oct 2, 2014 | 11:45 AM
ditto's Avatar
ditto
Those bushings are the easiest part of a 996 suspension to remove/replace or lube. Maybe 5 minutes a pop once the car is on stands.
Old Oct 2, 2014 | 08:59 PM
Gator996's Avatar
Gator996
Well, just came in from the garage. Everything got a nice lubing (the suspension, you freaks). On jack stands, the noise is gone. On the ground it sounds like an old farm truck. After the lube session the horrendous squeaking is still there. It squeaks over bumps and when turning wheel.
Since the symptoms didn't appear until after the roll bar install, it is coming out this weekend.
