996 Forum 1999-2005
techie water temperature stuff.....
Old Jul 10, 2014 | 03:24 PM
Ahsai's Avatar
Ahsai
Originally Posted by mikeborden
I read somewhere that oil temp is supposed to be 5c. If you can add a custom PID to your reader.
I thought about trying to add it, but I was scared to add a custom PID, cause in the app it gives me a warning about adding custom PIDS.
Anyone want to try the 5C for a custom PID.
Mike
My understanding is "5C" is the standard one defined by the OBDII spec for oil temp but it's optional for a car to support it or not (Porsche chose not to report it via the OBDII standard PID). The "Torque" app automatically queries all supported PIDs defined and it's not returning oil temp so I don't think you could get that reported via a generic OBDII scanner.
The oil temp however is available via Durametric that uses Porsche proprietary protocol. I don't think it's as simple as using a custom PID in Torque to retrieve. I would like to be proven wrong though as the oil temp is definitely something lots of folks here are interested in.
Old Jul 10, 2014 | 04:00 PM
mikeborden's Avatar
mikeborden
Originally Posted by yoda888
Would love to learn what apps and what OBD2 devices people are using. In particular if you're using an iPhone as my understanding is that a lot of the Bluetooth OBD2 devices don't work with iPhones.
I'm particular interested in the water and oil temps.
Thanks!
To get my Iphone to work with the ELM327 Bluetooth, I had to jailbreak the phone and install two other apps for the bluetooth to work. Then installed OBD Fusion.
The two "other" apps did cost me about 10bucks.
It was a pain in the butt and if you're not willing to hack your Iphone, I'd go with the WIFI version, which is supposed to work without jailbreaking your phone.
Old Jul 11, 2014 | 06:23 AM
mcbit's Avatar
mcbit
Thanks!
I purchased the WIFI code reader below from Amazon and OBD Fusion from the AppStore - no jailbreaking/ hacking involved. Worked fine straight out of the box but no oil temperature as mentioned in my earlier post.
Old Jul 11, 2014 | 08:19 AM
dgjks6's Avatar
dgjks6
Originally Posted by phil996cab99
Not to hijack the thread, but question for all:
Any technical reasons come to mind to explain inconsistent cooling (on the same day)?
For example, let's say my thermostat fully opens at 180, A/C always on so low speed fans always on, high speed fans turn on at 225 (I know).
Driving in suburban neighborhood, no traffic, no sitting, just the occasional stop signs. So we can factor out traffic and driving style.
The 1st temp. drop happens at 195 and drops to 190. It's consistent (every day). After it tests 195 a few times, it breaks thru and rises to 212.
The 2nd temp. drop happens at 212 and drops to 208. As before, it tests that 212 mark a few times before breaking it, and then it's on to 225.
What I can't figure out is the inconsistency of those two pause levels (195 and 212). Why do they hold sometimes and sometimes not. Is routing randomness possible eg. expansion tank, condenser, oil cooler.
Keep in mind the car is fully warmed up. I run these tests, then let the car cool a bit, them run them again, same results. Thanks.
I am not a Porsche certified mechanic but I have a theory on your car, and I don't even know if it is possible. You temperature sensor is bad. If you have a stock themostat, the first temp drop should happen around 180 not 195. If you temp sensor is off 15 degrees (the difference between 195 and 180) then all of you readings fall into line with what everyone else is reporting.
Old Jul 11, 2014 | 09:03 AM
DBJoe996's Avatar
DBJoe996
Stuck thermostat, or perhaps your sensor is gummed up. Now having said that, and having to assume that your water pump impellers are not worn, thermostat is working properly, coolant is at the correct level, mixture and fresh, and your temperature sensor is working properly, your fans are running consistently, air flow through your radiators is consistent and not blocked, and your engine oil is fresh, proper weight and at the correct level, why are you concerned (even in theory) about a 5-7 degree difference in a five hundred pound piece of metal pounding away at 3,000+ RPM with controlled internal cylinder explosions at 4,500 degrees F? There are so many variables at play here.
Old Jul 11, 2014 | 10:01 AM
phil996cab99's Avatar
phil996cab99
Thanks, I'll check and report back.
Old Jul 11, 2014 | 10:14 AM
phil996cab99
Originally Posted by DBJoe996
Stuck thermostat, or perhaps your sensor is gummed up. Now having said that, and having to assume that your water pump impellers are not worn, thermostat is working properly, coolant is at the correct level, mixture and fresh, and your temperature sensor is working properly, your fans are running consistently, air flow through your radiators is consistent and not blocked, and your engine oil is fresh, proper weight and at the correct level...
Good list for me to work thru. I'll make a new thread so as to not sidetrack this one (nods to OP).
Old Jul 11, 2014 | 01:25 PM
RngTrtl's Avatar
RngTrtl
I too may have to investigate this. I would love to be able to read what the ECM thinks the oil temps are.
Old Jul 11, 2014 | 03:37 PM
Ahsai's Avatar
Ahsai
Please keep us posted
Old Jul 11, 2014 | 03:48 PM
mikeborden's Avatar
mikeborden
If you find it, I'll be glad to try to add the PID to my OBD reader.
