Arrived today: K&N 57-7000 Intake
subscribing. have one in a box in the garage, it came on my car, but i pulled it and put back the stock one. found it a bit loud, and i don't track anyway. very curious to see actual numbers and durametric results.
Your results will be interesting but not necessarily applicable to others due to the other mods you appear to have that potentially affect output as well. I also note that the K+N chart posted is for the 3.6, I believe you have the 3.4, do they have a chart for that as well? Not ******* on your plan at all, just pointing out differences. Your baseline dyno pull will be interesting to compare to K+N's baseline.
I'm guessing it will be next to nothing on the dyno. I have the EVO and didn't notice anything. The only reason I bought it was the previous owner broke the factory airbox mount nub and it wouldn't stay in place. IMO, they only belong or FI.
Wow, how obvious & simple, but I never thought of it. If at the same RPM, the MAF shows the same airflow, then its doing nothing. If there's more, then there has to be more HP at that spin. I also look forward to the results.
A warning about the KN. One the oil on the cone filter will kill your MAF sensor. Get the dry filter with the mesh. Also I had the unit on my car for a week and took it off. The car off the line will suck in hot air and it killed the performance off the line. Then on the highway it would work great and sound great. So to me it wasn't worth it. It did sound great but not much HP gain. I have a 3.8 upgrade when the IMS went. Got new pistons and sleeves from LM engineering. I ended up getting the 3.8 Stock 997 air box. Looks and sounds great.
Robert
Robert
Robert
Robert
