996 price with gt3rs looks and power!! Project stormtooper underway!!
yeah, i feel he got the good end of the deal after finding all the "surprises". I didnt fit good in the fd though @ 6'4, but i made myself fit, it was a cool little car.
More parts showed up! Got my ls6 headers w/ AIR delete plates cleaned up and painted. Coolant sensor, TB elbow, and header install hardware arrived. Headers took all of about 5 mins to install! I did run into the problem that i got a 99-02 ls1 coolant sensor which is a 2-wire, but my 98' ls1 harness has the pigtail for a 3 wire sensor, so now i have to get a 99+ pigtail.
Got some work done! Re-installed the motor/trans, ran a few coolant lines, ran the steam ports. Still need to work on the driver side coolant hose to waterpump, passenger side is done.
I got my new 2 wire coolant sensor pigtail soldered in.
Need to trim a little more off the body/motor mount to fit the heater hoses onto the waterpump.
Ran an oil catch can for the vents in the driver side valve cover.
There is a shot from underneath, shows the ls6 manifolds and it still has the f-bod pan on. I still need to install the batwing pan. I picked up an ls6 mid pipe with pre cats and cats, going to figure some way to fit all that. It still will be crazy loud i'm guessing.....hopefully we'll find out in a couple days!! :devil:
Going to fab up an exhaust and finish putting the body work on and i'll have some driving vids.
