Attn spin-on filter adapter users...
Following LN Engineering's recommendations, the filter needs to be changed more often than the oil.
Anyone using the spin-on adapter: approx. how much oil is lost when replacing a spin-on filter? I'm assuming the experience will be similar to changing one of the cartridges, but I want to ensure that I don't wind up with 9 quarts of oil on the floor...
Depends on which spin-on filter you use but none hold as much as the OEM "cup" so you shouldn't have more than 1/2 qt.
Good quality filter, (K&N, Wix, Mobil 1,etc.) should last 10,K miles so I just change mine at 5,K miles with the oil.
OP said that LN recommends changing filter more often than oil. Wanted to know how many ounces of oil are needed to top off. My guess is that the guys at LN being overly cautious feel the need to inspect your filter more regularly than every 5k. Cheap insurance.
It's because the adapter eliminates the bypass in case the filter becomes clogged enough to block oil flow. Highly unlikely unless there is a major engine failure in progress. This insures the oil is filtered under any condition, but it is not idiot proof. In any event I prefer any foreign material be contained in the filter instead of bypassed throughout the engine via the oil.
Bob
01 C4
31 Ford cp chp & ch, 302/350
40 ******, 302/350, IFS
38 Ford cp, 327/350, IFS
57 Belair
62 356B --long ago
