Clutch pedal went soft and couldn't put it into any gears - 2003 C4S
#31
Out of curiosity, how many miles do you have on your 996? Do you drive in a lot of stop and go traffic which requires you to depress the clutch a lot? Or any hard launches?
#32
I got the clutch kit off of ebay for $500+tax (sachs) which is the same as OEM or it is OEM (so I was told) did the labor myself and paid $80 for resurfacing of the flywheel as I had some burn marks on it and also did RMS only at the same time. All together it was around $700 as I recall.
#33
https://rennlist.com/forums/996-foru...5-minutes.html
Maybe these are related, as the solution to my horrible noise was the incorrect assembly of the release arm, and it had not been greased properly when changed.
#36
So I decided to take it to my Indy. I'll be dropping it off Sunday night and they'll be working on it during the week. Porsche Ottawa were booked until June 3rd lol. Although they said to drop it off and they can work on it if they free up. I wasn't going to take the risk of not having it for a month, and it kicking around in a parking lot with tons of clients swinging doors beside it.
I have a really good indy, and this way I'll save $800 if the flywheel just needs surfacing/machining.
I'll be getting the RMS and IMS looked at and most likely going to get the RMS done since it's right there.
I'm sure I could of purchased the Sachs clutch kit online and saved $100, but that's alright...
Now... the shop is about a 25 min highway ride, I could flatbed it using a friends CAA, and offer him some cash of course, or I can take it late late Sunday night and drive in 2nd up until the highway on-ramp, stop and shut the car off, put it in 3rd, and let it catch speed on the on-ramp and drive in 3rd all the way to the off-ramp, stop and repeat steps to get it in 2nd and drive the car that way to the shop...
Life's problems eh...
#38
Update - It was the pressure plate that failed. Flywheel will be machined/resurfaced. RMS was slightly leaking so that will be changed. IMS looked good and since it's a "newer" engine, I will leave it as is.
One thing that surprised me was that the mechanic noticed a "rubber part" which was starting to crack that he suggested I replace. He mentioned it is a $500 part... Does anyone know which he is referring to?
I find it really ashame that a car at this pricepoint has this many weaknesses. Slightly dissapointed actually.
#40
So if the rubber coupling can be replaced without splitting the trans/motor then I doubt it's the same part.
#41
My hats off to Zookie for identifying the problem over the internet...
Topaz, are you the original owner? Do you drive it hard? How many miles? I am still surprised the PP failed (not so much in Zookie's case because of his duty cycle)? I could see maybe with a few hard launches, coupled with the AWD traction might be quite stressful on the PP?
#42
I am the 3rd owner. First owner was a owner of a VW dealer in California and didn't drive it for long until selling it to his friend, I then bought it off him (millionaire).
There was a new Porsche motor installed (warranty) in late 2005 due to scored cylinders. Also, when I bought the vehicle 4 years ago there was a new clutch kit installed so I thought I was golden in that sense (new engine, new clutch). I have full service docs on the car. It currently sits at 96 kilometers. I bought it at about 50 Kilometers.
I've been driving standard cars all my life and I'm VERY meticulous about the way I shift. I drive this car like every Porsche owner should, harder at times but never track-hard. I open it up a bit here and there (Italian tune-up) and I know that these cars need to be driven properly. I don't do much stop and go either. I feel like this was just a odd fluke of it failing... I can't explain it any other way. The clutch itself was hardly even worn out. The Flywheel was in top shape as well.
I love the car to death, but just by looking at the occurrences of problems, it’s a disappointment. I haven’t had a single problem with the car until this incident though and I admit that, but If I bought new, it would’ve been a different story.
I am debating on selling it after I fix the clutch (which will be tomorrow).... Someone will be getting a really well sorted car with a solid engine and brand new clutch kit car. Ideally it would be an optimal time to sell. Still debating though. I’m trying to get into a 2009 Vantage next but the selection in Canada is a little on the weak side thus I’d preferably like to go to the U.S for my purchase. The problem is the CAD is sitting very low and the conversion rate will be a big factor.
